603,936 active members*
2,211 visitors online*
Results 1 to 11 of 11
    Aug 2009
    9
    Exclamation Programming a series of holes!
    Hi guys
    I need help programming a plate am working on just now, i can upload a drawing of this plate and the sizes but its just i cant get anywhere with it because there is so many holes to input, can someone write a program out for me that i can just copy to my bridgeport?
    Thasnks alot
    Jan 2005
    1121
    and the control would be........?
    Aug 2009
    9
    Bridgeport series 2 interact 4 mate
    Aug 2009
    9
    cnc plate
    cnc plate
    Attached Files Attached Files
    Jun 2007
    3738
    Looks like a meatmincer plate?
    Complicated arrays just aren't simple.
    You either need a CAM program, or learn how to program.
    All the holes are in straight lines and are equally spaced,so one way is to write a subroutine that you specify the start point, and the number of holes in the row and the step to the next hole.
    When all that is done you you write a higher level program that figures out the start points.
    That's how I did it 15 years ago, with no CAM software.
    Once the start point is specified, you the subroutine can use incremental amounts for the step, and a counter for the number of holes, or you you can absolute like used here.
    The subroutine needs turns off incremental when done otherwise it becomes confusing.
    Is it stainless steel? I imagine so, and you need to run the same program with a center drill first before you start drilling.
    Once you read the manuals and learn how to program it just gets easier.
    This program was for a larger plate than your program, very similar number of holes.!!!!!!!!!!! Geez, I thought I was done with that job.!!
    With all those holes you probably need a method with lots of M1s so you can set optional stop when the drill sounds like it needs changing.
    I used 2 drills, and while one was running, sharpened the spare.
    Or you could use replaceable drill tips like Iscar have.
    This was using a BOSCH CC120 controller, but if you print this out and read it you should be able to figure how I did it.
    BSRPxx is subrountine call. The subroutines are after N142
    BEQP32 is Branch if equal to $32
    All the $XXs are labels for branching.
    Vxx is a variable name.
    TSTVx tests the variable before a conditional branch.
    Where it says SWITCH OFF, the machine had a test to see oif an option switch was on or off. G23 Pxx is where the switch is tested.
    This is how the operator interacted with the program.
    This didn't use G83 drill cycle, but that would be the better way to do chip-breaking. N324 is where the hole is drilled.
    As you see it is the deepest nested part of the program.
    I can answer the odd question to clear this up but after not doing it for 15 years, nor having any emulation software, I can't write it for you.
    At a guess this drill 564 holes using about 400 lines of code.
    Center drilling, 6.8mm hole, then 8mm and 12mm, or there may have been all three different hole sizes.
    Can't remember too much. It just worked, and the operator followed the prompts.
    Code:
    (DFS,P 18,DR.SHREDDER PLATE.M,RWED)
     N 1    (PLATE.NC   05-FEB-1996)
     N 2    M00
     N 3    (TURN ON SWITCH TO SKIP INSTRUCTIONS - HIT START)
     N 4    (12MM    6.8 AND 8MM DEBURR DEPTH)
     N 5    VDA=-6.6 VDB=-4  VDC=-4.3
     N 6    ()
     N 7    ()
     N 8    ()
     N 9    ()
     N 10   G23 P13
     N 11   M00
     N 12   (G54 IS ZREF FOR CENTRE DRILL 1 MM ABOVE JOB)
     N 13   M00
     N 14   (G55 IS ZREF FOR 6.8MM DRILL 1 MM ABOVE JOB)
     N 15   M00
     N 16   (G56 IS ZREF FOR 8.0MM DRILL 1 MM ABOVE JOB)
     N 17   M00
     N 18   (G57 IS ZREF FOR 12MM DRILL 1 MM ABOVE JOB)
     N 19   M00
     N 20   (G58 IS ZREF FOR DEBURRING DRILL 1 MM ABOVE JOB)
     N 21   M00
     N 22   (REFERENCE POINT IS CENTRE OF JOB)
     N 23   M00
     N 24   (SET G54 G55 G56 G57 G58 X AND Y AT CENTRE OF JOB)
     N 25   (-----------------------------)
     N 26   $13
     N 27   M00
     N 28   (NEXT STEP STARTS PROGRAM)
     N 29   M6 T0303
     N 30   T00
     N 31   S9
     N 32   F100
     N 33   G0
     N 34   (PITCH OF HOLES IN Y V0P = 9.5)
     N 35   V0P=9.5
     N 36   (SET UP SELECTED SEQUENCES)
     N 37   BSRP35
     N 38   (-=-)
     N 39   TSTV30
     N 40   BEQP31
     N 41   M00
     N 42   (INSERT CENTRE DRILL -- TOOL 3)
     N 43   G54
     N 44   V0X=0 V0Y=-141.12
     N 45   X=V0X Y=V0Y
     N 46   G0 Z0
     N 47   M3
     N 48   (DEPTH OF DRILLING MOTION IS 3MM)
     N 49   V0D=-3
     N 50   BSRP41
     N 51   BSRP51
     N 52   BSRP61
     N 53   M5
     N 54   G0 Z200
     N 55   X0 Y0
     N 56   (-=-)
     N 57   $31
     N 58   TSTV31
     N 59   BEQP32
     N 60   M00
     N 61   (INSERT 6.8MM DRILL -- TOOL 3)
     N 62   (------)
     N 63   S9
     N 64   G55
     N 65   V0X=120 V0Y=0
     N 66   X=V0X Y=V0Y
     N 67   G0 Z0
     N 68   M3
     N 69   (DEPTH OF DRILLING MOTION IS 17.5)
     N 70   V0D=-17.5
     N 71   BSRP50
     N 72   M5
     N 73   G0 Z200
     N 74   X0 Y0
     N 75   (-=-)
     N 76   $32
     N 77   TSTV32
     N 78   BEQP33
     N 79   M00
     N 80   (INSERT 12MM DRILL -- TOOL 3)
     N 81   (------)
     N 82   S7
     N 83   G57
     N 84   V0X=95 V0Y=0
     N 85   X=V0X Y=V0Y
     N 86   G0 Z0
     N 87   M3
     N 88   (DEPTH OF DRILLING MOTION IS 197)
     N 89   V0D=-19
     N 90   BSRP40
     N 91   M5
     N 92   G0 Z200
     N 93   X0 Y0
     N 94   (-=-)
     N 95   $33
     N 96   TSTV33
     N 97   BEQP34
     N 98   M00
     N 99   (INSERT 8MM DRILL -- TOOL 3)
     N 100  (------)
     N 101  S9
     N 102  G56
     N 103  V0X=0 V0Y=-141.12
     N 104  X=V0X Y=V0Y
     N 105  G0 Z0
     N 106  M3
     N 107  (DEPTH OF DRILLING MOTION IS 18.5)
     N 108  V0D=-18.5
     N 109  BSRP60
     N 110  M5
     N 111  G0 Z200
     N 112  X0 Y0
     N 113  (-=-)
     N 114  $34
     N 115  TSTV34
     N 116  BEQP49
     N 117  M00
     N 118  (INSERT DEBURRING DRILL -- TOOL 3)
     N 119  (------)
     N 120  S9
     N 121  G58
     N 122  V0X=0 V0Y=-141.12
     N 123  X=V0X Y=V0Y
     N 124  G0 Z0
     N 125  M3
     N 126  (DEPTH OF DRILLING MOTION IS 3)
     N 127  G1 F60
     N 128  (SET V0D FOR DEPTH OF EACH TYPE)
     N 129  V0D=VDA
     N 130  BSRP41
     N 131  V0D=VDB
     N 132  BSRP51
     N 133  V0D=VDC
     N 134  BSRP61
     N 135  M5
     N 136  G0 Z200
     N 137  X0 Y0
     N 138  (-=-)
     N 139  $49
     N 140  M2
     N 141  (============= END ===============)
     N 142  ( SUB ROUTINES )
     N 143  (--------------)
     N 144  $40
     N 145  (12 MM DRILL TOOL 3 - S7 - === 3 HOLES)
     N 146  G1 F40
     N 147  $41
     N 148  V0Q=1 V0X=95 V0Y=0
     N 149  BSRP77
     N 150  V0Q=1 V0X=-47.5 V0Y=82.27
     N 151  BSRP77
     N 152  V0Q=1 V0X=-47.5 V0Y=-82.27
     N 153  BSRP77
     N 154  G99
     N 155  (---------------)
     N 156  $50
     N 157  (6.8 MM DRILL - S9 - === 3 HOLES)
     N 158  G1 F35
     N 159  $51
     N 160  V0Q=1 V0X=120 V0Y=0
     N 161  BSRP77
     N 162  V0Q=1 V0X=-60 V0Y=103.9
     N 163  BSRP77
     N 164  V0Q=1 V0X=-60 V0Y=-103.9
     N 165  BSRP77
     N 166  G99
     N 167  (---------------)
     N 168  $60
     N 169  (8.0 MM DRILL - S9 - === 558 HOLES)
     N 170  G1 F35
     N 171  $61
     N 172  (NEXT TWO LINES ARE FUDGE FOR SHORTCUT)
     N 173  TSTV33
     N 174  BNEP59
     N 175  V0Q=7 V0X=0 V0Y=-141.12
     N 176  BSRP77
     N 177  V0Q=7 V0X=-8.23 V0Y=-145.87
     N 178  BSRP77
     N 179  V0Q=7 V0X=-16.45 V0Y=-141.12
     N 180  BSRP77
     N 181  V0Q=7 V0X=-24.68 V0Y=-145.87
     N 182  BSRP77
     N 183  V0Q=7 V0X=-32.91 V0Y=-141.12
     N 184  BSRP77
     N 185  V0Q=5 V0X=-41.14 V0Y=-136.37
     N 186  BSRP77
     N 187  V0Q=3 V0X=-49.36 V0Y=-131.62
     N 188  BSRP77
     N 189  V0Q=2 V0X=-57.59 V0Y=-136.37
     N 190  BSRP77
     N 191  V0Q=1 V0X=-56.0 V0Y=-71.25
     N 192  BSRP77
     N 193  V0Q=4 V0X=-64.23 V0Y=-85.5
     N 194  BSRP77
     N 195  V0Q=7 V0X=-72.46 V0Y=-99.75
     N 196  BSRP77
     N 197  V0Q=10 V0X=-80.68 V0Y=-114
     N 198  BSRP77
     N 199  V0Q=26 V0X=-88.91 V0Y=-118.25
     N 200  BSRP77
     N 201  V0Q=23 V0X=-97.14 V0Y=-104.5
     N 202  BSRP77
     N 203  V0Q=22 V0X=-105.36 V0Y=-99.75
     N 204  BSRP77
     N 205  V0Q=21 V0X=-113.59 V0Y=-95
     N 206  BSRP77
     N 207  V0Q=18 V0X=-121.82 V0Y=-80.75
     N 208  BSRP77
     N 209  V0Q=15 V0X=-130.05 V0Y=-66.5
     N 210  BSRP77
     N 211  V0Q=12 V0X=-138.27 V0Y=-52.25
     N 212  BSRP77
     N 213  V0Q=5 V0X=-146.5 V0Y=-19
     N 214  BSRP77
     N 215  V0Q=10 V0X=-80.68 V0Y=28.5
     N 216  BSRP77
     N 217  V0Q=7 V0X=-72.46 V0Y=42.75
     N 218  BSRP77
     N 219  V0Q=4 V0X=-64.23 V0Y=57
     N 220  BSRP77
     N 221  V0Q=1 V0X=-56.0 V0Y=71.25
     N 222  BSRP77
     N 223  V0Q=2 V0X=-57.59 V0Y=126.87
     N 224  BSRP77
     N 225  V0Q=3 V0X=-49.36 V0Y=112.62
     N 226  BSRP77
     N 227  V0Q=5 V0X=-41.14 V0Y=98.37
     N 228  BSRP77
     N 229  V0Q=7 V0X=-32.91 V0Y=84.12
     N 230  BSRP77
     N 231  V0Q=7 V0X=-24.68 V0Y=88.87
     N 232  BSRP77
     N 233  V0Q=7 V0X=-16.45 V0Y=84.12
     N 234  BSRP77
     N 235  V0Q=7 V0X=-8.23 V0Y=88.87
     N 236  BSRP77
     N 237  V0Q=7 V0X=0 V0Y=84.12
     N 238  BSRP77
     N 239  V0Q=7 V0X=8.23 V0Y=88.87
     N 240  BSRP77
     N 241  V0Q=7 V0X=16.45 V0Y=84.12
     N 242  BSRP77
     N 243  V0Q=7 V0X=24.68 V0Y=88.87
     N 244  BSRP77
     N 245  V0Q=7 V0X=32.91 V0Y=84.12
     N 246  BSRP77
     N 247  V0Q=7 V0X=41.14 V0Y=79.37
     N 248  BSRP77
     N 249  V0Q=7 V0X=49.36 V0Y=74.62
     N 250  BSRP77
     N 251  V0Q=8 V0X=57.59 V0Y=69.87
     N 252  BSRP77
     N 253  V0Q=9 V0X=65.82 V0Y=55.62
     N 254  BSRP77
     N 255  V0Q=10 V0X=74.05 V0Y=41.37
     N 256  BSRP77
     N 257  V0Q=11 V0X=82.27 V0Y=27.12
     N 258  BSRP77
     N 259  V0Q=12 V0X=90.5 V0Y=12.87
     N 260  BSRP77
     N 261  V0Q=10 V0X=98.73 V0Y=17.62
     N 262  BSRP77
     N 263  V0Q=10 V0X=106.95 V0Y=12.87
     N 264  BSRP77
     N 265  V0Q=9 V0X=115.18 V0Y=17.62
     N 266  BSRP77
     N 267  V0Q=8 V0X=123.41 V0Y=12.87
     N 268  BSRP77
     N 269  V0Q=6 V0X=131.64 V0Y=17.62
     N 270  BSRP77
     N 271  V0Q=5 V0X=139.86 V0Y=12.87
     N 272  BSRP77
     N 273  V0Q=1 V0X=148.09 V0Y=17.62
     N 274  BSRP77
     N 275  V0Q=1 V0X=148.09 V0Y=-17.62
     N 276  BSRP77
     N 277  V0Q=5 V0X=139.86 V0Y=-50.87
     N 278  BSRP77
     N 279  V0Q=6 V0X=131.64 V0Y=-65.12
     N 280  BSRP77
     N 281  V0Q=8 V0X=123.41 V0Y=-79.37
     N 282  BSRP77
     N 283  V0Q=9 V0X=115.18 V0Y=-93.62
     N 284  BSRP77
     N 285  V0Q=10 V0X=106.95 V0Y=-98.37
     N 286  BSRP77
     N 287  (NEXT TWO LINES ARE FUDGE FOR SHORTCUT)
     N 288  $59
     N 289  V33=0
     N 290  V0Q=10 V0X=98.73 V0Y=-103.12
     N 291  BSRP77
     N 292  V0Q=12 V0X=90.5 V0Y=-117.37
     N 293  BSRP77
     N 294  V0Q=11 V0X=82.27 V0Y=-122.12
     N 295  BSRP77
     N 296  V0Q=10 V0X=74.05 V0Y=-126.87
     N 297  BSRP77
     N 298  V0Q=9 V0X=65.82 V0Y=-131.62
     N 299  BSRP77
     N 300  V0Q=8 V0X=57.59 V0Y=-136.37
     N 301  BSRP77
     N 302  V0Q=7 V0X=49.36 V0Y=-131.62
     N 303  BSRP77
     N 304  V0Q=7 V0X=41.14 V0Y=-136.37
     N 305  BSRP77
     N 306  V0Q=7 V0X=32.91 V0Y=-141.12
     N 307  BSRP77
     N 308  V0Q=7 V0X=24.68 V0Y=-145.87
     N 309  BSRP77
     N 310  V0Q=7 V0X=16.45 V0Y=-141.12
     N 311  BSRP77
     N 312  V0Q=7 V0X=8.23 V0Y=-145.87
     N 313  BSRP77
     N 314  G99
     N 315  (---------- $77 -------- HOLE DRILLING ROUTINE)
     N 316  ( DRILLS V0Q HOLES AT V0X V0Y - DEPTH = V0D)
     N 317  $77
     N 318  V8=V0Q
     N 319  BRAP9
     N 320  ()
     N 321  (-- LOOP BACK TO HERE --)
     N 322  $8
     N 323  V0Y=V0Y+V0P
     N 324  (-- $9 -- START HOLE HERE --)
     N 325  $9
     N 326  G0
     N 327  X=V0X Y=V0Y
     N 328  BSRP88
     N 329  (DRILL THE HOLE)
     N 330  G1
     N 331  Z=V0D
     N 332  G0 Z0
     N 333  $78
     N 334  DECV8
     N 335  BGTP8
     N 336  G99
     N 337  (------------------)
     N 338  $88
     N 339  ()
     N 340  ()
     N 341  ()
     N 342  ()
     N 343  G23 P79
     N 344  BSRP80
     N 345  $79
     N 346  G99
     N 347  (------------------)
     N 348  $80
     N 349  M5
     N 350  G0 Z200
     N 351  M00
     N 352  M3
     N 353  G0 Z1
     N 354  $81
     N 355  G99
     N 356  (----------------------)
     N 357  $35
     N 358  V30=1 V31=1 V32=1 V33=1 V34=1
     N 359  M00
     N 360  (SWITCH OFF TO SKIP CENTRE DRILLING)
     N 361  ()
     N 362  ()
     N 363  ()
     N 364  ()
     N 365  G23 P36
     N 366  V30=0
     N 367  (-----)
     N 368  $36
     N 369  M00
     N 370  (SWITCH OFF TO SKIP 6.8MM DRILLING)
     N 371  ()
     N 372  ()
     N 373  ()
     N 374  ()
     N 375  G23 P37
     N 376  V31=0
     N 377  (-----)
     N 378  $37
     N 379  M00
     N 380  (SWITCH OFF TO SKIP 12MM DRILLING)
     N 381  ()
     N 382  ()
     N 383  ()
     N 384  ()
     N 385  G23 P38
     N 386  V32=0
     N 387  (-----)
     N 388  $38
     N 389  M00
     N 390  (SWITCH OFF TO SKIP 8MM DRILLING)
     N 391  ()
     N 392  ()
     N 393  ()
     N 394  ()
     N 395  G23 P39
     N 396  V33=0
     N 397  (-----)
     N 398  $39
     N 399  M00
     N 400  (SWITCH OFF TO SKIP DEBURRING)
     N 401  ()
     N 402  ()
     N 403  ()
     N 404  ()
     N 405  G23 P44
     N 406  V34=0
     N 407  (-----)
     N 408  $44
     N 409  M00
     N 410  (TURN SWITCH ON)
     N 411  M00
     N 412  (USE RAPID TO SKIP HOLES)
     N 413  G99
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    May 2004
    402
    But what is the CONTROL
    Quote Originally Posted by Robert_Downs View Post
    I am guessing it is probably a Heidenhain control - possibly a TNC145 or TNC150 or TNC155 . Your drawing says no G or M codes - so what do you want it programmed in - possibly Heidenhain Conversational but that will still use M codes.
    When posing questions like this it really does help if you give the forum the facts needed - after all you are asking strangers (NOT MATES !!!!) to help you and spend their time solving your problem.
    Andrew Mawson
    East Sussex, UK
    May 2006
    807
    There are .PDF to .DXF converters out there, then verify dimensions and adjust the numbers to match, load the circles in a cam system and go. two hours cad labor.
    Been doing this too long
    Aug 2009
    684
    I'd program the top 60deg sector of 90 holes then rotate the program and repeat it. You could save initial programming time doing each row of holes as an incremental loop, but I would actually put each individual co-ordinate in to give more flexibility for restarts should the tools need touching-up or replacing mid-program.
    DP
    Jan 2005
    1121
    you have rotate, lbl call angular moves at your disposal. You have a very inconvenient pattern as I cannot pick up the repeats in it quickly
    May 2004
    402
    There is a program called plantincnc intended for pcb making, that will take your source file and locate the holes and give you co-ordinates - it will also give you G code to drill them if you wish.
    PlatinCnc home
    I have used it (actually on a Bridgeport Interact as it happens) where I scanned the image of a complex gasket that I needed multiples of, and made a stack of them. Worked a treat.
    Andrew Mawson
    East Sussex, UK
    Jan 2005
    1121
    something like
    X0 Y122.309
    CYCLE CALL
    CALL LBL 1
    CALL LBL 1
    L X-? Y115.514
    CALL LBL 1
    CALL LBL 1
    LBL 1
    IX 7.846
    CYCLE CALL
    LBL 0
    STOP
    STOP
    STOP
    you cna only call a label with a rep of more than zero once, there is a workaround, put the lbl at the end , because when you screw up lbl repeats, it blows through lbl 0 with unpredictable results. Create 6 labels that all say:
    LBL 2[and 3 and 4 and 5]
    CALL LBL 1
    LBL 0
    STOP
    STOP
    don't forget the stops in case it doesn't work
    if ther is no reason for this particular pattern, redraw it with a series of concentric holes and you can write the whole plate with like 20 lines of code total
    LBL 2
    LP I10 F2000 R0[syntax]
    CALL LBL 1
    LBL 0
    CALL LBL 2 REP 99999[whatever]
  1. Replies: 5
    Last Post: 08-31-2010, 04:48 PM
  2. Just got a Series IISD - need help programming
    By g35fanatik in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2009, 01:57 AM
  3. Series II R2E4 Programming
    By AppEng in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2008, 01:01 AM
  4. Just how strong are the holes in a Series I base?
    By AviatorDave in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2008, 12:48 AM
  5. Bridgeport Series II CNC w/ BOSS - Programming
    By rocknrolljunky in forum Bridgeport / Hardinge Mills
    Last Post: 09-11-2007, 07:56 PM
