603,358 active members*
3,202 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Proper Connection of Shuttle Jog Controller.
Results 1 to 4 of 4
    Nov 2004
    284
    Hi Guys
    I am finalizing the wiring between my Keyboard and Computer and have a question on hooking up the USB Devices. Can you run the Shuttle Jog Controller from one of the Mini Keyboard USB connectors or should you run a separate USB line back to the Computer? What about for the Mouse and USB Hub? I understand that normally, USB devices can be plugged into each other but I am not sure if this is true with CNC controls?
    I will have the following USB items:
    (1) Keyboard
    (2) Mouse
    (3) Shuttle Jog Controller
    (4) USB Hub for Memory Stick.
    Should I run separate USB lines for each item or can they be piggybacked?
    Thanks for your help.
    Willy
    Feb 2007
    246
    Hey Willyb, I ran my shuttle and mouse right off my mini keyboard and it works fine. Some others had problems with this setup, so I cant guarantee that it will work out for you.
    With the flash drive, mine wouldn't work through the keyboard. I ended up running a USB cable from the PC cabinet to the tool cabinet under the machine table. Its a bit of a pain to go in there to load a program, but a lot easier than the PC cabinet.
    Live free or die
    Feb 2006
    1051
    Based on my unpleasant experience of using a hub, I have all each USB component on its own extension cable back to the PC. When they were plugged into a hub there were motion glitches and inconsistent jogging.
    For all I know, it might have been the hub I was using. But I figured it was safer not to be daisy-chaining another hub to the hub already built into the motherboard.
    Best regards,
    Randy
    Nov 2004
    284
    Thanks Guys for your help with my question.
    I think I will go with a separate USB lines for the Keyboard, Mouse, Shuttle Jog and Memory Stick. I have enough problems with Computers with out asking for it. Just need to order some USB Extension cables. Hope my Shuttle Jog shows up soon and I can get this wired up. Thanks again.
    Willy
  1. Jog Pendant or Shuttle Controller?
    By keen in forum Tormach Personal CNC Mill
    Last Post: 09-04-2007, 03:47 PM
  2. VF2 Alarm 125 - Shuttle Fault, quick fix?
    By JMFabrications in forum Haas Mills
    Last Post: 07-12-2007, 09:51 PM
  3. Parallel Port machine controller to computer connection HELP PLEASE!
    By whipsnade in forum DNC Problems and Solutions
    Last Post: 08-01-2006, 10:45 PM
  4. Proper Use of TEACH?
    By squarewave in forum CamSoft Products
    Last Post: 06-25-2005, 01:30 AM
  5. Hirobo Shuttle Metal Fan
    By mroy0404 in forum Hobby Discussion
    Last Post: 05-07-2005, 06:07 PM
