587,420 active members*
3,180 visitors online*
    Oct 2009
    19
    Proper Router tools
    I will be using a 1/4 trim router for my machine.
    What type of cutters are recommended for the following?
    Wood (small signs or 2d stuff)
    Plastic (small panels for flightsim project, with small letters)
    Metal (thin aluminum pieces)
    Craig
    Feb 2006
    210
    I have gotten to where I do most of my work with an engraving bit--1/4 in carbide. Works well in wood or plexi with proper speeds. then I use a 1/4 or 1/8 spiral upcut carbide for any flat areas. This does about 95% of my carving. I do a lot of plaques in oak and foundry patterns in wax and tooling board. I just got the tooling board (48 psf). Boy is it great! but expensive!
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Nov 2009
    7
    Quote Originally Posted by aviatorskate View Post
    Craig
    We use negative helix HSS mills for routing thin sheet aluminum. The negative helix prevents the metal from lifting up as it is cut.
    Example: 8000rpm 40 in/min feed with 1/4 cutter 0.032 "O" condition 2024 aluminum.
  1. Any info on a Digital Tools CNC Router?
    By xscsime in forum Commercial CNC Wood Routers
    Last Post: 01-29-2017, 07:48 PM
  2. Any info on a Digital Tools CNC Router?
    Last Post: 10-30-2007, 03:05 AM
  3. Real machine tools on router?
    By rustamd in forum DIY CNC Router Table Machines
    Last Post: 06-09-2007, 05:38 AM
  4. Router Tools for liteply and balsa
    By planekrazie in forum DIY CNC Router Table Machines
    Last Post: 01-20-2007, 05:44 AM
