603,850 active members*
4,476 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Proper way to program chamfer
Results 1 to 5 of 5
    Sep 2005
    140
    Hi all
    I have never used the chamfer feature until now, and I am in need of some help.
    The tool is a 5/16 90 degree chamfer 4 flute chamfer bit. What I am unsure about is how to tell bobcad what to do. i remember in Sorin's class he showed us how but can not remember.
    Say I want to put a .030 chamfer on the edges of a rectangle. what information do I put in the boxes in bobcad to get that?
    Walt
    May 2008
    244
    walt
    put .312 tool in data base
    draw a 2 in rectangle
    make this your stock
    do a contour so you can climb mill the od
    pattern offset left
    parrameters chamfer length .030
    select sharp tool, angle 90 deg.
    cutter position of .030 so the sharp tip is not cutting
    then go to tool cham mill
    manual select your .312 tool
    anytime you make a change any where go back to parameters page and make sure
    your depths or lengths are still the same i use this for corner round also
    Sep 2005
    140
    Thanks a bunch!!
    Walt
    May 2007
    715
    The one thing I wish it would allow is a way to step into the chamfer. I have a couple of parts that I am making that require a full 45 degree face that is .174. I want to do a "Rough" chamfer then come back around with a finish chamfer but it looks like the only way to do it is add 2 ops in the tree.
    Jul 2010
    369
    To do a chamfer without two operations in the cam tree just choose profile and setup your tool as needed dia. chamf. angle...etc..
    Then choose under param multiple steps total depth .174 number of passes 2
    This is what I came up with when I made a chamf tool and on a random rectangle made a .174 deep chamfer with 2 passes using the profile feature.
    Hope this helps you some ..Good Luck~!:cheers:
    Attached Thumbnails Attached Thumbnails ChamferSolid.jpg   chamfer toolpath.jpg
  1. 2D chamfer
    By jcnewbie in forum Mastercam
    Last Post: 10-19-2009, 05:06 AM
  2. can we program 3D chamfer
    By Bala in forum Mori Seiki Mills
    Last Post: 02-20-2009, 08:00 PM
  3. How to program a chamfer cutter - M Plus
    By brismit in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-24-2008, 04:16 PM
  4. Chamfer
    By CharlesM479 in forum Solidworks
    Last Post: 04-12-2007, 05:13 AM
  5. Using a 45 deg chamfer tool
    By COPO427 in forum Mastercam
    Last Post: 01-14-2007, 07:28 PM
