turn your vision into business. :rainfro:
:cheers:With our proseries bedmill, generate profit from your creativity. By using our top seling MACH3 software, you can renber your tool's paths into G-codes. Then use your G-codes from your model to creat complex shapes made out of wood, plastic, or metalthat that can be machined by our 4" axis capable Proseries bedmill.
The additional axis allows you to perform complex rotary machining normally done on expensive industrial equipment at a fraction of price.By taking advantage of our combination of accessories you too can sophisticated geometrical designs.
:banana:HM-200 CNC MILL
Specification:
machine weight:532.97kg
Footprint:36''*24''
Shipping weight:625.96kg
Table size:40''*12''
Table travel x axis:22''
Saddle travel y axis:11''
Head travel z axis:11.5''
T-slot size:5/8''
Slot on table,qty. :4
Spindle :
Motor hp rating:2hz
Min. speed:150rpm
Max. Speed:4000rpm
Spindle taper: R-8
Positioning accuracy: + or -0.0005''
Quill diameter:3.15''
Axis
Stepper motor(xyzaxis):1700 in-oz
Ball screw size(x axis):0.984''
Ball screw size(y axis):0.984''
Ball screw size(z axis):0.787''
Ball screw pitch:0.196''
Ball screw precision
5
