587,645 active members*
3,079 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Prototrak Z Offset tool setting question
    Jun 2016
    9
    Question Prototrak Z Offset tool setting question
    Let's say tool 1 is a 1/2" end mill and tool 2 is a .250" drill. Since the drill is longer the Z Offset has to be set. I put a .001" feeler gauge on the top of the part. Then I jog the head down and touch the feeler gauge with tool 1 and press Z, ABS/Set to zero it out. Then load tool 2 and go to the jog function and touch this to the feeler gauge. Once that touches the feeler gauge, I can go back to the tool table and under the the Z offset column and press ABS/Set This automatically calculates the difference and sets the Z zero point for that tool.
    Do I have this correct?
    Re: Prototrak Z Offset tool setting question
    did you figure this out? sounds like your doing something wrong. if you need help i can walk you thru this. let me know.
    L.S. Tool & Precision Inc.
    Taking machining to the
    next level, combining creativity, ingenuity and the technology of CAD/CAM & CNC Machining
    “When ingenuity makes all the difference”
    http://hometown.aol.com/lstool1/myhomepage/business.html
  1. SETTING TOOL OFFSET TO A HEAVY TOOL
    By WINGNUT66 in forum Fanuc
    Last Post: 12-01-2019, 10:30 AM
  2. Meldas 520A setting tool offset memory type I
    By kalimero in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-31-2015, 01:10 AM
  3. New Tool Length Offset Setting Device
    By ljh34481 in forum News Announcements
    Last Post: 12-13-2012, 01:21 PM
  4. Offset and tool setting
    By mtnhntr in forum Mori Seiki lathes
    Last Post: 01-10-2011, 03:28 AM
  5. tool touch off and offset setting
    By Runner4404spd in forum Fadal
    Last Post: 02-16-2009, 01:48 PM
