587,997 active members*
3,672 visitors online*
Results 1 to 4 of 4
    Aug 2014
    7
    proximity switches
    I'm using a C35s BOB for my G0704 mill and want to use proximity switches like these Inductive Switch Assembly to RJ45, CNC4PC
    I'm having trouble with Mach 3 seeing all switches, at the moment it will only show 1 on the -Y.
    All switches came wired into a rj45 plug. All built in switch lights are on and do flash on or off when metal is placed in front of them.
    Jim
    Re: proximity switches
    Hello i'm new in this forum.
    I reviewed your problem and I think the proximity should be attached to the RJ45 connector 7 not the RJ45 8.
    Mar 2007
    2083
    Hi Jim
    looking at the links from this web page for the C34 bob and the proximity switch kits
    its not obvious to me which switch kit you have
    if you have the 3 axis kit plugged into the C35's RJ45 socket 8 and the pin 11 jumper set to socket 7
    then I can see why Mach 3 will only see the Y axis limit switches
    ( pin 10 = Y axis limit switch)
    Attachment 291590
    the way the 2 proximity switches for each axis are wired Mach 3 can only see a switch has been operated but not which one
    Attachment 291592
    how have you assigned the input pins in Mach 3's pins and ports ?
    use RJ45 socket 7 ,
    pin 13 = Z limit switch
    pin 12 = Y limit switches
    pin 11 = X limit switches and jumper on the C35 set for socket 7
    John
    Aug 2014
    7
    Looks like I had the switches plugged into socket 7.
    Now when it triggers a limit switch, I can't "reset" or manual move away from the triggered switch. I have to disable the triggered switch.
  1. Looking for Proximity switches.
    By Marwell in forum Want To Buy...Need help!
    Last Post: 01-08-2009, 10:42 PM
  2. PROXIMITY SWITCHES
    By CHANDRU in forum CNC Machine Related Electronics
    Last Post: 12-12-2007, 02:33 PM
  3. PNP v/s NPN Proximity Switches
    By whiteriver in forum CNC Machine Related Electronics
    Last Post: 05-17-2007, 05:10 PM
  4. proximity switches
    By woodguy7777 in forum Commercial CNC Wood Routers
    Last Post: 04-29-2006, 10:17 PM
  5. Proximity switches
    By bgriggs in forum DIY CNC Router Table Machines
    Last Post: 09-01-2003, 06:13 AM
