603,940 active members*
2,104 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Coding > PTAP2DXF - make paper tapes without a punch
Results 1 to 5 of 5
Hybrid View
1944GPW PTAP2DXF - make paper tapes... 12-08-2017, 04:01 AM
bostosh Re: PTAP2DXF - make paper... 12-08-2017, 06:14 AM
warrenb Re: PTAP2DXF - make paper... 12-08-2017, 07:03 AM
bostosh Re: PTAP2DXF - make paper... 12-08-2017, 03:33 PM
1944GPW Thanks for your comments... 12-14-2017, 03:37 AM
    Dec 2017
    G'day all,
    This is my first post on IndustryArena, please be kind
    I've written a small open source command line utlity called PTAP2DXF that makes paper tapes without using a tape punch.
    Rather, it generates DXFs for cutting workable 8-level, 5-level and other-level paper tapes using a normal home CNC craft stencil cutting machine, the sort that is generally used for making Xmas and Birthday cards.
    It's mostly directed towards vintage computer enthusiasts who might have a paper tape reader but not a punch, but maybe someone here could find it intreresting.
    You can find it on Github at https://github.com/1944GPW/ptap2dxf
    I've written a 26-page illustrated user manual PDF for it which is in the Documentation folder.
    https://github.com/1944GPW/ptap2dxf/...anual_v1.0.pdf
    For Windows users, I've put a precompiled PTAP2DXF.EXE executable there, if you're not fussed on building it yourself.
    I'ts written in portable C# on .NET Core so it is buildable and runnable on Linux and Mac as well.
    If you try it I'd be interested in any comments, bug reports and so on.
    Thanks and regards,
    Steve Malikoff.
    Brisbane, Oz
    May 2006
    807
    Re: PTAP2DXF - make paper tapes without a punch
    I am impressed, and wonder why......not a negative wonder .....
    I ran parts with 1" analog mag tape, miles of punched paper and mylar, learned ro read BCD and fix tapes
    Yeah we made parts that went into space that way.
    Been doing this too long
    Mar 2008
    684
    WOW!!!
    I was going to say "get a hobby" but you have one.
    Now I feel bad throwing away that old tape reader / punch on the Tree CNC machine I rebuilt a few years back.
    Great work.
    May 2006
    807
    Tape length and misreads were the bane of tape,
    imagine 4 spindles 4 parts and a read error. oohhhh s**t
    yes that happened. .
    Clean the reader every shift. Tension arms stretching mylar tapes.
    One job 20 tapes. normal stuff
    We switched to 1/2" mag tape cassettes and 7" floppy's with BCL for B-1 at Rock-et-well.
    Thank goodness for read reliability and unlimited tape length.
    Dec 2017
    Thanks for your comments guys, I appreciate it.
    The reason I wrote the program came about when my wife bought the little CNC craft cutter to make cards and decorations on. I saw it in a different light, rather as a way to make engine and transmission gaskets and marking stencils for my WWII vehicle restoration hobby. These turned out excellently.
    Not having a currently working punch for my vintage computers (I have an ASR33 teletype to be worked on someday) I was intrigued to find out the limits of the cutter's resolution so I ran tests on cutting the sprocket and data holes in tape and to my surprise it was no problem at all, and it grew from there.
    I'm about to start on the option to make 80-column IBM punched cards... not that I have a card reader, but mostly for fun
    Steve.
