587,138 active members*
3,827 visitors online*
Thread: Puma
    May 2006
    265
    Puma
    If I make a small taper. ex W-200U0.05, metric.. I get some visual "rings" every 17th mm, I can feel them too, a straigth cut in z direction doesnt give me this kind of surface. Any ideas?
    Jan 2005
    49
    Could be the material that you are using I had this happen to me I was machining 4140 hot roll and had the same problem , to test this out to see if it does it all the time you will need to try to machine a different type of material with the same program to see if you get the rings that you are talking about if that doesn't do it you may have slop in your ball screws or your gibbs may need adjusting , hope this helps.
  1. Daewoo puma 8s
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 06-14-2010, 07:58 AM
  2. Puma 560 Robot
    By puma560 in forum RC Robotics and Autonomous Robots
    Last Post: 01-26-2010, 02:02 PM
  3. Puma 280 singleblock...
    By _Kristian_ in forum Daewoo/Doosan
    Last Post: 07-11-2008, 07:03 PM
  4. Puma 10-HC part
    By binzer in forum Daewoo/Doosan
    Last Post: 08-27-2007, 03:07 PM
  5. Fanuc 0 & Puma 12L
    By Green Button in forum Daewoo/Doosan
    Last Post: 03-06-2007, 12:14 PM
