588,529 active members*
6,984 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 10HC Parts ID and sourcing
Results 1 to 8 of 8
    Oct 2017
    23
    Question Puma 10HC Parts ID and sourcing
    I've been working to diagnose an intermittent chatter that our operator has been mentioning.
    PUMA 10HC
    Ser # PH100157
    Upon inspection I found there to be a lot of play in the z-axis slide's y direction (up/down). I removed the wipers, hoping to find a gib screw to adjust the clearance but the only adjustment is for the z direction.
    Looking more closely, I found the problem. The plastic friction material that the turret rides on in the carriage has been pushed out the top of the spindle side of the slide, see picture.
    I'm at a loss as to what to call this stuff and where to get it. I do have a parts manual but the drawings are not very clear.
    Anyone who knows what to call this stuff and/or where to get it would be appreciated
    Oct 2017
    23
    Re: Puma 10HC Parts ID and sourcing
    TURCITE!
    That's the name I was looking for.
    Now to find a place that will sell me a small amount and some glue.
    Next task is to figure out how to lift the cross slide out of the machine without screwing up, the ballscrew has me a bit worried and the parts book drawings aren't much help there.
    Mar 2003
    2932
    might be a place to start: https://mtsandtg.com/turcite-b-lf
    Oct 2017
    23
    Quote Originally Posted by dcoupar View Post
    Thanks,
    I did send them a RFQ and they replied promptly. Also they were , by quite a bit, the most reasonably priced source of turcite and glue I found.
    Feb 2013
    788
    I hope you know that scraping turcite is a skill. It needs to be hand scraped to allow the surfaces perfect alignment.
    Just saying...If you don't know that it is called Turcite, it is highly unlikely that you have the skills needed to install it correctly.
    I am not trying to insult, just to inform.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Oct 2017
    23
    Quote Originally Posted by dhardt View Post
    No worries, you have a valid point.
    I do have a little experience scraping in an old manual mill so I'm willing to give this a try, do some reading and learn by doing.
    The lathe is unusable at this point so I don't think I can make the machine all that much worse.
    Feb 2013
    788
    I would suggest hiring someone skilled in the process and learning the finer points from them.
    It's like learning martial arts...I can tell you what a reverse punch is, I can show you what a reverse punch is.
    Done wrong, you have a high likelihood of breaking your hand...
    See attached documents for the basic info.
    Oct 2017
    23
    Thanks dhardt for the guide and info.
    After much cleaning, measuring, cutting, measuring, scaping, measuring, blueing, measuring, and more measuring I manged to get the turcite installed and the lathe trammed back in.
    Accuracy is as good or better than before the problem started and tool offsets are back to reasonable numbers.
  1. Daewoo Puma 10HC - Some keys not working?
    By dutchmichael in forum Daewoo/Doosan
    Last Post: 02-19-2016, 05:19 PM
  2. Puma 10HC parameter problem
    By Sastrom in forum Daewoo/Doosan
    Last Post: 10-21-2014, 01:37 PM
  3. daewoo puma 10hc
    By j.lyons in forum Daewoo/Doosan
    Last Post: 04-24-2013, 01:59 AM
  4. Deawoo Puma 10hc alarm 27
    By RP Jr. in forum Daewoo/Doosan
    Last Post: 07-16-2012, 06:31 PM
  5. OLD PUMA 6S, 10HC
    By oleggch in forum Daewoo/Doosan
    Last Post: 09-15-2011, 01:44 PM
