603,844 active members*
4,680 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 240 gives an error 2023
    Dec 2013
    8
    "Each tool indexing is not finished within 10 sec.After toolindex command (manual or auto)".
    1 tool causes no problems. For all other error 2023, sometimes changes sometimes not. But the error is constant.
    I would be grateful for your help.
    Dec 2013
    8
    Problem was solved.
    Helped standard [Machine Home setting methode] with parameter 0.8.001 then 1 - tool position.
    First put the wrong value, then the right. The machine worked.
  1. HELP! kia lathe al 2023 alarm problem
    By kimorbrand in forum News Announcements
    Last Post: 11-14-2023, 10:38 AM
  2. PUMA 2000sy VS PUMA 2100sy
    By GreggC in forum Daewoo/Doosan
    Last Post: 10-03-2013, 11:51 AM
  3. Puma 8S Spindle Amplifier error code 34
    By naveng in forum Daewoo/Doosan
    Last Post: 12-30-2009, 05:02 AM
  4. 940 pcb error puma 8s
    By inderan2005 in forum Daewoo/Doosan
    Last Post: 07-22-2008, 01:44 AM
  5. puma 8s 940 pcb error
    By inderan2005 in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2008, 02:45 PM
