603,932 active members*
3,382 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach 4 > Purchasing a new CNC Router, vendor provides Mach3 profile. Usable in Mach4?
Results 1 to 5 of 5
    Dec 2017
    6
    All, I am a relative noob. I have spent the last year using an X-Carve with Universal G-Code Sender. I am getting a 4x8 CNC and the vendor provides a Mach3 profile for use with the machine. Can the Mach 3 profile be converted to Mach 4?
    I figure If ArtSoft is moving ahead with Mach 4 (and I have no previous experience with Mach 3), I might as well learn on the new software. I'd rather not pay for Mach 3, then turn around and purchase Mach 4 later.
    Your thoughts? Can I take the profile the vendor gives me and use it with Mach4?
    Mar 2003
    35494
    Re: Purchasing a new CNC Router, vendor provides Mach3 profile. Usable in Mach4?
    No, Mach4 is completely different than Mach3, and can not use a Mach3 profile.
    And there's a good chance that the Mach3 motion controller that comes with the machine will not work with Mach4 either. I've only heard of one chinese motion controller that works with Mach4, and I've heard that it doesn't work very well.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2017
    6
    I was going to use the UC100 USB motion controller. Thanks for your input, probably saved me some money.
    Mar 2003
    35494
    Yes, the UC100 will work with Mach4.
    If you're using the UC100, consider UCCNC, which is only $60, and is imo superior to Mach3.
    For a 4x8 router, consider using a UC400ETH or UC300ETH, which provide a lot more inputs and outputs for only a little more money.
    Gerry
    Dec 2017
    82
    Mach4 is totally different than mach3 .
    As Gerry said , you can use uc300 with its own software instead mach .
  1. need help to onnect my 6040 3 axis cnc router to mach4
    By mcdoggie in forum News Announcements
    Last Post: 07-26-2017, 08:13 AM
  2. Mach4 Setup in Chicago - looking for some help for a day - 5x10 router needs TLC.
    By skylineworkshop in forum Mach Software (ArtSoft software)
    Last Post: 12-26-2016, 10:44 PM
  3. Replies: 1
    Last Post: 02-11-2016, 04:39 AM
  4. Machine Profile for a Syil Super X3 using Mach4
    By Megaplow in forum Machines running Mach Software
    Last Post: 09-20-2015, 01:16 AM
  5. Going to buy a new router 1325b or 1325bg what vendor
    By dgalaxy in forum Chinese Machines
    Last Post: 09-07-2014, 10:41 AM
