603,853 active members*
5,019 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463 > PURPLE MILLenium - G0463 Build Thread
Results 1 to 4 of 4
    Oct 2010
    36
    Here's yet another build log of a G0643. I will try incorporate a lot of lessons learned from many of you who have done this before, but my main reason for having this build log is because I will need some help as I go along for answers I could not find.
    I received my G0463 about two weeks ago and the build began. Here are other parts I have ordered....
    - CNC Fusion Deluxe Kit w/ helical couplings.
    - PMDX132 Breakout/Motherboard (I have used this same setup in my CNC Router)
    - PMDX135 Power Prep Module
    - Gecko 203V Stepper Drivers
    - Honeywell roll lever limit switches
    I have not yet procured steppers. Will likely do tomorrow. Are there any good sources to get steppers from? I hear of Keling quite a bit, but wondering who else sells good steppers.
    This is all the components I have for now.
    I will build the control box once I can locate a good enclosure. Do you guys have any suggestions?
    I am building a stand and will post progress on that later.
    And now for some pictures............
    Pics 1, 2 & 3 - Out of the box and during tear-down.
    Pics 4 & 5 - Prepping for paint. I decided to change the color. Hence, PURPLE MILLenium:
    Pics 6 & 7 - Paint drying.
    Jan 2010
    2141
    Just curious - how did you prep for the paint. what type of paint did you use, and are you happy with the results?
    Oct 2008
    1660
    Looks nice. Just an idea, You ought to tape the ways on the Z (Column) and paint it as well along with the Z Bracket. You really can't oil it on a regular basis and it will rust pretty bad if your not carefull.
    Richard
    Mar 2009
    388
    Quote Originally Posted by LTHOMPS View Post
    I bought my steppers and control from www.candcnc.com He sells complete turnkey motors/controls/enclosures. A 3 axis 620oz in setup is $845. This thing is built like a tank, and works great. Saved a ton of time for me.
    Scott...
    Instructional Videos for CNC Guitar Building
    http://www.rmgvideos.com
  1. Looking for a build thread (SX3 - CNC)
    By sagreen in forum Benchtop Machines
    Last Post: 03-17-2012, 06:02 PM
  2. Not a build thread
    By rocketflier in forum DIY CNC Router Table Machines
    Last Post: 11-05-2011, 06:22 AM
  3. Mint's Build Aluminum/Steel Build thread.
    By FreshMint in forum Maintenance DIY Discussion
    Last Post: 10-31-2011, 04:18 AM
  4. AXYZ Millenium Question
    By sharp_custom in forum Want To Buy...Need help!
    Last Post: 04-27-2011, 03:44 PM
  5. tool changing with AXYZ Millenium
    By frankbergeron in forum G-Code Programing
    Last Post: 07-17-2007, 01:33 PM
