Attachment 179739
Switch off of the mosfet can be quite fast.
As flywheel current flows through the diode, you must turn on the mosfet slowly, longer than reverse recovery time of diode, other wise the mosfet is a short across the supply for the duration of reverse recovery. Usually for your current a 150 ohm resistor in series with the gate will slow it enough.
You need a 15v zener between the cathode and the source (anode of diode to left of choke and cathode to the gate).
This is to prevent large transients damaging the mosfet.
For the diode use a schottky diode for best results.
ON Semiconductor MBR4015CTL: 40 A, 15 V Schottky Rectifier
ref:Semiconductor Products
The mosfet needs to be rated at 60A or more.
The gate drive needs to be relative to the source (bottom of mosfet) so quite a bit of other circuitry is required.
I am just showing the principle here. The gate needs to be driven 10-15v above the positive supply.
Done correctly, this will run almost cold.
Search for application notes using google for more details.
You still need a good heatsink for the mosfet and the diode that can disipate around 30-40W at full load.
This will give excellent low speed performance provided the mosfet has a high enough current rating.
This circuit will do a DC transformation to the lower voltage the PWM is commanding.
You can find some sophisticated circuits that can have a controllable current limit too.
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
