587,167 active members*
3,626 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > PWM not allowing max spindle speed
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Oct 2019
    20
    Re: PWM not allowing max spindle speed
    I am having a similar problem I think. Whenever we try and increase the speed of our spindle using the Mach3 software it does not stop until it reaches the maximum speed. Any ideas as to why we cannot control the speed. We have a KL-6590 CNC machine with a Furing DZB300 series inverter. I do not know the brand of the breakout board is, but it is a bi-directional parallel BOB.
  2. #22
    Jan 2005
    15362
    Quote Originally Posted by BJM737 View Post
    First you have to see if the PWM and analog 0-10v is working this is at the your Breakout Board is where you need to check this if this is not working the VFD is not going to respond to anything but what ever that output is
    Mactec54
Page 2 of 2 12
  1. Replies: 3
    Last Post: 04-20-2019, 11:24 PM
  2. Replies: 0
    Last Post: 06-10-2016, 03:08 AM
  3. Fanuc AC Spindle Drive speed does not match S-code speed
    By serickson in forum Spindles / VFD
    Last Post: 10-13-2014, 01:18 PM
  4. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
