603,978 active members*
1,348 visitors online*
Thread: PWM Query
Results 1 to 6 of 6
    Jul 2006
    367
    PWM Query
    Hello folks, I recently acquired an Electrocraft 1300 servo driver. In reading the manual, I saw that this unit can have a analog (+-10v) or a PWM signal (software configured) attached to the same terminal.
    Here is the description from the manual....
    "Dual purpose Input. Software configured.
    + Differential Command Signal Analog Input. Zero to ±10 Volt external
    command signal input. The polarity of this signal controls the relative applied
    direction of output motor torque, velocity, or position. Input is protected to
    ±24 Volt maximum.
    Or
    PWM Control Input. Zero to +5 Volt logic signal. TTL compatible. +24 VDC
    maximum signal amplitude. 0 Volts minimum. 10K Ohm input impedance.
    Positive true logic. Weighting of PWM On‐time Vs Off‐time controls the
    amount of commanded torque, velocity, or position".
    Being a complete newbie at the servo game, would the PWM in the above statement be the same PMW that Mach3 puts out (to control a spindle) ?? or is this step-direction????
    thanks
    pete
    Dec 2003
    24260
    Basically yes, the principle is the same for both.
    Al.
    Albert E.
    Jan 2006
    2985
    Dec 2003
    24260
    Quote Originally Posted by keebler303 View Post
    Check here for some detail:
    Matt
    That link shows PWM to analogue, I assume the O.P. is looking to go PWM direct into the drive, bypassing the analogue in?
    Al.
    Albert E.
    Jan 2006
    2985
    I suspect the useful bit of the document is the talk about setting up a PWM spindle in mach3. Once you get the PWM signal out of mach3, the hard part is done.
    Matt
    Jul 2006
    367
    Quote Originally Posted by Al_The_Man View Post
    Al.
    Al your the man That's what I was hoping to do...I'll give it a whirl on the test bench.
    thanks
    pete
  1. Boxford 125 query.
    By SKennedy in forum DNC Problems and Solutions
    Last Post: 08-02-2008, 10:43 PM
  2. QUERY ABOUT USING MACROS
    By girishnadkarni in forum Fanuc
    Last Post: 06-11-2008, 03:38 PM
  3. Tapping Query
    By SPEEDRE in forum MetalWork Discussion
    Last Post: 12-21-2006, 02:05 AM
  4. Yet Another Bearing Query...
    By itsme in forum Mechanical Calculations/Engineering Design
    Last Post: 12-19-2006, 12:42 AM
  5. Encoder Query
    By bean7795 in forum CNC Machine Related Electronics
    Last Post: 04-29-2005, 02:10 AM
