603,767 active members*
2,759 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > QC30 - Tool Holder Falling Out of Spindle
    Jun 2021
    Question QC30 - Tool Holder Falling Out of Spindle
    Hello, I own a Bridgeport Boss 5, with what I believe is a Series 2J head. It has the Erickson QC30 spindle. It works fine when taking very light cuts, but today I was taking a (fairly conservative cut) with a 1/2" Carbide End Mill. It was all going great until the tool holder fell out of the spindle suddenly, destroying my work piece and tool.
    This has happened 3 or 4 times with this machine now. It has a solid spindle with no drawbar or hole for one.
    Has anyone run into this issue before? What can I do to prevent this? The spindle nut was incredibly tight.
    Dec 2013
    5720
    Re: QC30 - Tool Holder Falling Out of Spindle
    Yup mine did the same thing until I figured it out. Loosen the nut another half turn or so, insert the tool holder, hand tighten about a half turn, the tool holder should still be loose. Make sure the tool holder is engaged in the spindle dogs. Try to pull the tool holder out, if it won't come out then tighten the nut and you should be good to go.
    If you still have some trouble I'll post some pictures.
    Jim Dawson
    Sandy, Oregon, USA
  1. Tool Holder sticks in Spindle
    By bushmaster556 in forum Haas Lathes
    Last Post: 04-27-2021, 06:26 PM
  2. Where to buy QC30 tool holders?
    By bhouin in forum Bridgeport / Hardinge Mills
    Last Post: 10-10-2014, 03:31 PM
  3. Replies: 10
    Last Post: 11-06-2012, 11:43 PM
  4. MV-40 tool falling during work
    By dango in forum Mori Seiki Mills
    Last Post: 04-04-2009, 04:05 PM
  5. Tool holder for spindle.
    By bunalmis in forum DIY CNC Router Table Machines
    Last Post: 07-19-2005, 10:56 PM
