588,127 active members*
5,267 visitors online*
Results 1 to 7 of 7
    Jan 2011
    qt 30 lost parameter
    hello..
    i have 1 machine qt 30 tplus controller . the parameter for this machine lost. i already key in back the parameter machine can on and zero return but still have alarm chuck type not selected . anyone can send to me the parameter for i double check.
    Jan 2008
    199
    Try looking for a switch that says internal or external chuck. Just toggle it from Internal to External then back and that should clear the alarm. Sometimes this switch is located in the electrical cabinet in the back and other times it's located inside a small little door on the operation panel where the DNC connector is located.
    Regards,
    Chippy
    Jan 2011
    thank for sharing. for information i already do toggle the switch but still not reset the problem. i hope you can give another solution.thanks.
    Jul 2007
    284
    Try moving the switch and then pushing the foot pedal three times, then flip the switch back and push the foot switch three times again. This should clear the alarm.
    Jan 2011
    nothing happen alarm still not missing
    Aug 2009
    71
    Need Help! qt 30 lost parameter
    Do you have the PLC Ladder Manual? If so, try to find the L Parameter for chucking type selection INTERNAL & EXTERNAL.
    If you get it, you can try forcing it in I/O Monitor screen.
    Best Regards,
    Girish
    Jan 2011
    thank.fyi when i toggle the swith in io monitor it was changed but it can't release the alarm.
  1. Viper V-950/OS crashed,lost all parameter
    By jesse297 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-18-2022, 07:45 PM
  2. VMC - SUPERMAX 60A parameter lost
    By rajesh_1355 in forum Fanuc
    Last Post: 02-12-2016, 02:11 PM
  3. I lost parameter biesse rover 316
    By mar404 in forum CNC Machining Centers
    Last Post: 07-28-2010, 10:54 PM
  4. I lost parameter rover 322
    By DANMI38 in forum CNC Machining Centers
    Last Post: 06-30-2010, 11:03 PM
  5. Fanuc 0M-C ---Parameter lost
    By rajappa in forum Fanuc
    Last Post: 06-13-2008, 12:25 AM
