588,099 active members*
5,080 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CamSoft Products > Quesion regarding inhibit jumper settings for Fanuc drive
    Mar 2005
    I am trying to find out jumper settings to inhibit Fanuc drives using a Camsoft/Galil 1840 motion control card with a 1900 I/O connection breakout box. The drive # for the jumper settings is A06b-6035 class and the top board is A20B-004-017. Anyone with any information on the jumper settings would be very helpful.
    Dec 2003
    24220
    Are you refering to the enable pin on the drive connector? I have the Honda plug pin out for the CN2 connector on A06B-6045 drive, the enable pin on these is pin 2 (enbl), the 6045 might be the same.
    Al.
    Albert E.
