603,783 active members*
2,783 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Question about 80/20 and Carriage Bolts
Results 1 to 4 of 4
    Oct 2011
    Hey all, can you guys tell me how well 5/16"-18 carriage bolts fit in the grooves of 80/20's 15-series struts? I've been drafting a cad model of the machine I'd like to build and it seems that the width of the bolts' square neck is bigger then the T-channel of the 15 series.
    McMaster's 5/16"-18 bolts have .324" necks and the T-channel of the 15 series range from .320" to .3121", depending on whether the 2 degree drop-lock feature is engaged. I'm getting the T-channel measurements from 80/20's own cad drawings.
    Nov 2006
    1036
    For my build, I used cheap carriage bolts that I buy by the pound at a local home center. Every one of the 5/16" carriage bolts fit just fine into every one of my 8020 series 15 extrusions.
    You prompted me to make some measurements. The slot size in a piece of 8020 scrap measured .321. The square neck of several carriage bolts measured between .308 and .312.
    Just remembered, I bought some of my carriage bolts from McMaster and they worked just fine too.
    Mar 2010
    371
    I got some 93548A587 bolts from McMaster. They worked fine in 3030 and 1530.
    Oct 2011
    Thanks for the reply guys! That'll cut down a bit on me second-guessing myself :P
  1. Need dimensions for housing bolts (not mounting bolts)
    By rcpilot82 in forum Stepper Motors / Drives
    Last Post: 09-22-2011, 02:29 AM
  2. Question about using nuts and bolts.
    By Broken Balsa in forum Commercial CNC Wood Routers
    Last Post: 03-03-2011, 04:25 PM
  3. Carriage Wheel
    By bling59 in forum MetalWork Discussion
    Last Post: 06-16-2009, 04:57 PM
  4. Carriage Jam
    By jroma1 in forum Mini Lathe
    Last Post: 07-01-2008, 04:05 AM
  5. Questions on Z Carriage
    By Goran321 in forum Joes CNC Model 2006
    Last Post: 12-20-2007, 03:21 AM
