I have a lot of parts and pieces that I have accumulated over the last couple of months and a whole lot of ideas, but I need to go ahead and start building something or it will end up becoming a mental exercise that is eventually forgotten.
I have several pieces from the CNCRouterParts 8020 design, but I do not have any of the 8020 pieces. The steel rails I have are for the 2x3 form factor so I want to go ahead and build a machine that size as a learning experience, but I eventually want to build a table that is 2x8 or 4x8 to use in building cabinets and built-ins for a new house we are planning to build. That being the case, I don't want to spend $400 on 8020 pieces that I won't be able to use on the larger machine. Would gluing 3/4" MDF together to make 1.5" MDF and then cutting it to the appropriate width and length to match the 8020 parts on the CNCRouterParts design result in a usable machine? I know the sizes of some of the bolts, etc. will change a bit since they will be going through the full 1/2" instead of just the t-slot area and I can accomodate that.
