587,754 active members*
2,966 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Question about collets and ridged tapping.
Results 1 to 16 of 16
    Apr 2005
    903
    Is it acceptable to use ER32/ER16 collets for ridged tapping?
    2008 Haas VF2D
    OneCNC XR5 Mill Expert
    Jul 2005
    12177
    I do. I use ER16 up to 1/4" or M6 and ER32 for larger sizes. I have never had a tap spin in a collet but I have stalled the spindle.
    Nov 2007
    1702
    Ditto, ER collets are all I have. What else were you considering?
    Greg
    Dec 2008
    319
    Quote Originally Posted by Geof View Post
    Geof-
    Curious what happens when you stall the spindle? What is the process of getting out of the jam??
    A few companies make tap collets with the correct diameter and a square built into the end of the collet.
    Tim
    Nov 2006
    490
    I have a set of the square collets he mentioned above. It works good when the regular TG or ER collets slip on the tap, which has happened to people in front of me a few times (though perhaps their own fault, who knows). Only thing about the square collets is they seem to be less resilient than a typical spring collet due to their design, or at least the ones I have are. What I mean is that one of the "spring" connections is not present on them (meaning the collet collapses like a spring pin to tighten). Not sure if all of em are like that. But I've broken about half of them. I just use ER now but then again I haven't had to "push" a rigid tapping cycle time in a while using anything other than small threads in aluminum...
    Jul 2005
    12177
    Quote Originally Posted by behindpropeller View Post
    Geof-
    Tim
    Onr time I just loosened the vise then raised the spindle and took everything out and unscrewed the tap holding the part in a bench vise.
    That was the easy one. The hard one was a part that needed more machining so I didn't want to disturb the setup. So I unscrewed it by hand which involved unscrewing slightly then jogging Z up a few thou then unscrewing a bit more. It was a taper tap so it became loose quite quickly and then the unscrewing and jogging was easy becaus if I jogged too far it would get tight.
    The actual stalling was very peaceful. It just came to a halt and I hit E-stop quickly before any alarms where triggered.
    Apr 2005
    903
    Quote Originally Posted by Donkey Hotey View Post
    Nothing really, I just wasn't sure if there was other tooling available other than a standard collet. Just checking.
    2008 Haas VF2D
    Feb 2009
    6028
    And that's when the rigid tap holder is very nice. Just pull up on the quick release and raise the head. Plus no tools required to change the tap.
    Aug 2010
    579
    I like the square collets because of the hard stop. When I have stalled the spindle, I loosen/remove the collet nut and jog z up, remove collet, and hand tap the hole.
    Thanks,
    Ken Foulks
    Nov 2007
    1702
    Quote Originally Posted by l u k e View Post
    And I just wanted to make sure you weren't thinking about Tapmatic heads, floating shanks or other such complications.
    Greg
    Feb 2008
    183
    I must be the odd one out, but all I use for taps is split sleeve tap drivers in tapered holders. I have collet holders but I use them more for endmills.
    Just push the button,what's the worst that could happen.
    Apr 2005
    903
    How do the ridged tap holders work? Is it similar to a collet but can be changed in the spindle?
    2008 Haas VF2D
    Apr 2005
    903
    I was just taking a look at some small thread forming taps I picked up for a job, the shanks are measuring odd diameters. The 6-32 measures.139" will a 5/32 collet lock that up?
    2008 Haas VF2D
    Feb 2008
    183
    Here are 2 links,and no you can't change a tool like a collet.
    MSC Item Detail
    MSC Item Detail
    Jul 2005
    12177
    Yes the grip range on ER collets is 1mm.
    Apr 2005
    903
    2008 Haas VF2D
  1. Replies: 4
    Last Post: 02-05-2011, 07:25 PM
  2. repeat ridged tapping setting.
    By mphjunky in forum Haas Mills
    Last Post: 10-28-2009, 05:24 AM
  3. ridged tapping for puma 240
    By outcastproducts in forum Daewoo/Doosan
    Last Post: 03-28-2008, 12:11 AM
  4. Another question about ER collets
    By Jonne in forum MetalWork Discussion
    Last Post: 11-13-2007, 07:30 PM
  5. Help Ridged tapping with 1/4-18 NPT tap please!
    By jrudicel in forum MetalWork Discussion
    Last Post: 01-18-2007, 01:09 AM
