Originally Posted by
starwind
I recently picked up the Artsign jsm-40.
It seems to be a nice laser machine.
I have mostly figured out Newlydraw1 and have it cutting and engraving after to re-aligning the mirrors.
I have a questions regarding some of the knobs and settings for those that have been using the machine for longer time.
1. The power knob (little gray knob used to adjust the power) should it make a circle (full turn) 10 times? The power does scale up but wondered if the 10 turns is normal (using it as 10% power for each turn currently.)
2. Does the ampere meter ever go higher than 20 mA? With the power knob turned all the way up?
3. Does anyone have suggestions for the speed and power settings in NewlyDraw1 for different materials? I know I can get most things by setting speed to 1 and power to max.
4. Mine came with some suggested settings in several sheets of paper. The sheets also included common troubleshooting things to check. It has suggestions for material and then speed, power, and step settings. The speed is in mm/sec (newlydraw1 has cm/sec) and for power they have settings from 1 - 12. Any idea what the power is referencing? Also where can step be adjusted?
