588,127 active members*
4,938 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Question on machining rectanglar draft relief after a cut out
    Sep 2009
    Hi
    I would like to cut out a rectangle draft (abt 15deg) on a 15mm thick.
    My procedure is as follows:
    1. Relief the rectangle and draft the angle
    2. Perform a cutout the material using endmill on a smaller vector
    3. Perform a Z level roughing with the 2 vectors selected
    The problem is that if I perform step 3 the tool path generated will try to finish the inner vector and this waste 50% of the time.
    Is there a way to label the inner vector as a keep off area or other method to machine this rectangular draft?
    Or any 3D cutout can follow the draft?
    thank you
    Benson
    Aug 2008
    409
    Quote Originally Posted by boxster View Post
    Hi
    thank you
    Benson
    Offset the inner vector at least 1/2 of your roughing tool diameter and Select the outer vector and the new offset inner vector and use "Selected Vectors" in the Z roughing tool path, it will only rough out the area between the selected vectors.
    You can save time if you only relief the draft angle, then do the cut out and Z Roughing, no need to relief the flat area as its already being done by the Z roughing.
    Sep 2009
    Hi Phief thanks for the advice
    I am using endmill of 6mm.
    In this case with the rectangular draft vector and offset inner vector selected, the cutter have to cover about 10.3mm at the top. (refer to attached cross section view)
    I guess there is no other better way out due to the material at the imaginary offset inner vector. The cutter had to move at least 2 times for each step of Z as I am using offset strategy
    Benson
  1. down draft vs. water
    By bakerj99 in forum Waterjet General Topics
    Last Post: 10-28-2010, 03:05 PM
  2. down draft table
    By patriot customs in forum Waterjet General Topics
    Last Post: 10-19-2010, 05:10 PM
  3. draft
    By dustinwassner in forum Moldmaking
    Last Post: 06-27-2010, 03:36 AM
  4. Down draft table?
    By grahamshere in forum DIY CNC Router Table Machines
    Last Post: 04-27-2008, 12:31 PM
  5. Water Table or Down Draft
    By hgarwood in forum Waterjet General Topics
    Last Post: 12-25-2007, 06:28 PM
