603,964 active members*
3,439 visitors online*
Results 1 to 4 of 4
    Feb 2009
    10
    Question on thread mill program
    Help,
    I have started running thread mills and have had very good results. My problem is when I try to run them on my big Matsurra I keep getting a invalid plane error when it gets to the helical interpolation. It is a Matsurra 2000 with a fanuc 11 control.
    I generated the program with Vardex thread mill generator and they run perfect on my 3 other mills. Any advice would be greatly appreciated.
    The program is something like this
    O0001 (TMINRH CLIMB Operation.Cycles= 1)
    (Tool cutting diameter = 0.516 inch - Fanuc 11M Controller.)
    G90 G00 G57 X0 Y0
    G43 H10 Z0 M3 S2664
    G91 G00 X0 Y0 Z-1.0084
    G01 G41 D60 X0.0329 Y-0.2796 Z0 F1.29
    G91 G03 X0.2796 Y0.2796 Z0.0084 R0.2796 F1.29
    G91 G03 X0 Y0 Z0.0909 I-0.3125 J0 F4.29
    G91 G03 X-0.2796 Y0.2796 Z0.0084 R0.2796
    G00 G40 X-0.0329 Y-0.2796 Z0
    G90 G00 Z8.0000
    M5
    M30
    Aug 2011
    2517
    most probably your machine does not have the Helical Interpolation option.
    Dec 2012
    410
    Didn't you forgot the G17 plane in the first line ?
    Call for T10 is maybe not necessary but the G17 is.
    Is your D60 value correct ?
    Regards,
    Heavy_Metal
    The Netherlands.
    Aug 2011
    2517
    G17 is defaulted by the control at power-on so it doesn't need to be in the program unless you have changed planes.
    he said the program works on other machines.
    in helical interpolation mode there is no plane selection because you are using all of the planes. it's not possible to specify all 3 planes. that's why you need the helical interpolation option.
    that alarm means the machine doesn't have the helical interpolation option.
  1. Thread Mill Program
    By october in forum G-Code Programing
    Last Post: 07-20-2016, 02:36 AM
  2. NEED THREAD MILL PROGRAM FOR C-AXIS
    By BAD DOG in forum Daewoo/Doosan
    Last Post: 03-05-2015, 04:59 AM
  3. Sample thread mill program
    By Captdave in forum HURCO
    Last Post: 03-11-2010, 02:37 AM
  4. Need help with simple thread mill program
    By Captain Midnigh in forum Milltronics
    Last Post: 07-24-2008, 11:57 PM
  5. 2-1/2 - 8 NPT Thread Mill Program
    By wesleybridgepor in forum MetalWork Discussion
    Last Post: 11-30-2006, 11:56 AM
