587,751 active members*
3,040 visitors online*
Results 1 to 14 of 14
    Oct 2011
    134
    Questions about the 770
    Hi All,
    I am looking to purchase the Tormach 770 + 4th axis, as a high end hobby mill for building parts for model airplanes. It will mainly be used to mill carbon fibre plate approx 3/32 and parts out of aluminium block.
    The questions that I have are:
    o) Does it come in a 240 V option ? if so what are the amps required ? as I am concerned that I need to go to 3 phase for 20 amps in Australia.
    o) Are you able to mill small aluminium parts say 5 inch's cubed without running a flood coolant system ? unfortunately I am limited on space.
    o) What Do you recommend the automatic manual / oiler?
    o) Is there significant advantage to running the touch screen over a normal screen ?
    o) I am also looking at the available controllers ? as I would like the unit to work out of the box... any recommendations about either Mach3 or EMC2
    Apologies in advance for the laundry list of questions.
    p.s. anyone have one of these machines in OZ ?
    Thank in Advance,
    Adrian
    Jun 2006
    2512
    OK I'll have a go.
    1) Don't know. IIRC the spec says 115V. Seems like they don't see an international market for the 770. You may need a transformer. Talk to Tormach.
    2) Milling without flood coolant isn't a problem. Mist coolant is a good compromise.
    3) If you run 20 hour 3D profiling programs then get the auto-oiler. Manual oiling for normal operation is more than adequate. You need to pull the handle once every 4 hours.
    4) A touch screen is not even remotely necessary.
    5) Mach3 is easily the default controller. If you don't know if you need EMC2 then you don't need EMC2.
    Phil
    Oct 2011
    134
    Thanks Phil,
    Appreciate your wisdom, I have spoken with the guys that bring these into Australia and they advised that my concerns re power are not going to be a problem which is great. 20Amp in Australia is can be difficult to drag into a housing unit in Australia.
    Interestingly I have heard that these machines have problems with running on earth leakage circuits ... does anyone know the story behind that ?
    Cheers,
    Adrian
    Jun 2006
    2512
    Quote Originally Posted by al010964 View Post
    Thanks Phil,
    That's a bit strong, anyway!
    If I were you I would email Tormach about the ELC issue, I remember reading a document written by them on the subject. Then talk to a local electrician about the best way to solve the power supply issue.
    Phil
    Feb 2008
    154
    Yes it may not work on a ELC outlet. It didn't here for me in the US, it kept triggering it. When I talked to Tormach about it they told me it was the spindle drive that was triggering it. But it may depend on the sensitivity of your ELC so you may not have a problem with in Australia. By the way, I agree with all Philbur said. I myself do not use coolant at all on mine. The only problem is that you need a way to blow the chips away, especially with aluminum. You can use compressed air, it works well. You can even use a simple solenoid valve to control the air blast with your gcode: MillIMods
    You should like the 770 very much. The only possible limitation I see is the size, in case you need to make large part or you need to make fixture to make several small one at a time. I am myself very happy with my machine.
    Christian
    Jun 2006
    3063
    Quote Originally Posted by concombrefrais View Post
    Christian
    Is ELC the same thing as GFCI here in America? If so, you might well have a problem running a VFD on a circuit equipped with that device. Something to do with feedback from the VFD triggering the GFCI.
    Mike
    Mar 2010
    5" cubed sure. But the height of the part being machined will depend on what size vise you are using, and the height of the tooling. Next time I have my vise on (Kurt D688) I will measure it, probably something I should know as well
    As for limited space? What does that have to do with the coolant? If you use the 770 stand it slopes under the machine and empties in the back, so even without coolant you will still end up with chips out the back of the machine. That is why I moved mine to a different location when I got it, you will need access to the back of the machine or build a plug to close of the back.
    I did. I didn't want to have to remember to manually oil it. It has been great so far no issues. You can even manually oil it if it has been sitting for a long time before you use it.
    Mar 2010
    Christian
    Same here. I do need some fixtures made that are bigger than the machine can machine. Have to think outside the box and consider modular fixtures... Maybe make two small one and then bolt them together on the machine.
    Oct 2011
    134
    Hi All,
    Sorry for the tardy response, been flat out. Will try and comment against everyone's post(s). The room that I am going to put the 770 in is getting built at the moment, so just instructed the sparky to run a non ELC line, which I will get hard wired to the machine, for safety reasons.
    Magnum164
    " As for limited space? What does that have to do with the coolant? If you use the 770 stand it slopes under the machine and empties in the back, so even without coolant you will still end up with chips out the back of the machine. That is why I moved mine to a different location when I got it, you will need access to the back of the machine or build a plug to close of the back. "
    Was planning on not getting the full stand and just making a custom stand, which wouldn't be able to catch the coolant. But now starting to think that I should possibly get the stand anyway .... just going to be a really tight fit in my home workshop. Anyone currently have this setup ? or am I just asking for a big mess ?
    Mike
    "Is ELC the same thing as GFCI here in America? If so, you might well have a problem running a VFD on a circuit equipped with that device. Something to do with feedback from the VFD triggering the GFCI."
    Having a quick look at the definition of a GFCI ... I would pretty much say yes. Don't know enough about the systems to say they are the same... but I think the principal is the same; e.g. stops you frying yourself when you do something stupid
    Christian
    Thanks for your comments - will check out that gcode command. Hopefully the size of the 770 won't be a real limitation as I plan on using for rc model plane stuff not production- that's the plan for this minute.
    Cheers,
    Adrian
    Jun 2006
    2512
    I think they have a similar function but achieve it in a different way. I seem to recall searching my power distribution board for the desirable initials GFCI. I'm sure Google will tell you the difference, if you ask him nicely.
    Phil
    Mar 2010
    What setup are you referring to? I have the 770 and stand. Its real nice. The stand is a lot Different than the 1100 stand. Better. I think in design.
    Sent from my DROID BIONIC using Tapatalk
    Oct 2011
    134
    Hi Mangnum164,
    Sorry the setup I was referring to was the 770 setup, on a custom stand as opposed the stand provide by tormach. I was thinking of doing this to reduce the foot print.
    Cheers,
    Adrian
    Mar 2010
    Hey no problem. Wasnt sure. Good luck.
    Dec 2010
    1230
    I got to play with the 770 and 1100 this weekend and definitely like the stands, but will build an enclosure around the top of the stand when I get around to ordering mine. the floor all around it (on all sides) was covered in chips and it wasn't doing heavy work. it did seem to contain the liquid as I didn't see any coolant on the ground.
    I would HIGHLY recommend calling Tormach before you place your order as there may be additional options in the next few weeks not on the website yet.
    very cool stuff. got to talk to the ATC manufacturer and see it in person, moves a lot faster in person than it seems in the videos. also got to dicsuss the upcoming slant bed in detail, most of the discussion was on ideas and goals. Once again I am thoroughly impressed with tormach's dedication to building intelligent products with modular/stackable design intent.
    make sure you order the jog wheel too. turns out it doesn't just look the the one I bought for my conversion... its the same one with different screen print and software. makes life much easier if you add a small rubber "button" or "stopper" with adhesive backing to the Z button so you can more accurately "feel" what axis you want to select. I did that the first time I jogged the wrong axis destroying a Haimer tip.
  1. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 10:42 PM
  2. Brass vs Aluminium Vs Steel, questions, questions and questions...
    By alexccmeister in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2011, 06:40 PM
  3. new with PET-G Questions
    By cadence in forum Vacuum forming, Thermoforming etc
    Last Post: 09-27-2007, 11:21 PM
  4. TM-2 questions
    By Zeekh in forum Haas Mills
    Last Post: 12-04-2006, 04:01 AM
  5. 3 questions--ok 4
    By monte55 in forum Machines running Mach Software
    Last Post: 11-03-2006, 03:22 AM
