603,365 active members*
2,910 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Questions on Micromill DSLS 3000
Results 1 to 5 of 5
    Mar 2008
    Question Questions on Micromill DSLS 3000
    Let me start by saying hellooooo this is my first post but I am not new to lathes and mills I have a Microlux lathe and a Microlux mill that I put DRO's on X,Y and Z axis and have a motor that is manual controled on the X axis. I hope to get a Micromill DSLS soon so here is my question for those of you that HAVE a MICROMILL DSLS 3000 by Microproto they say that you need a Printer port DB-25 to plug into BUT most laptops today do not come with this port so I was thinking of getting a adapter cable from DB-25 to USB will this work??? I have tried to contact Micromill but got no response THANKS for all the help.
    Tim
    Jan 2007
    525
    Nope, the USB to Parallel adapters don't work. You need a "real" 25-pin parallel port.
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Mar 2008
    PCMCIA Serial I/O Adapter
    What you need is a PCMCIA Serial I/O Adapter, I use one of these connect to my Cisco equipment works great. Try http://www.blackbox.com/files/productdetails/12506.PDF
    Mar 2008
    Quote Originally Posted by JohnstonAG View Post
    Do you KNOW that this works with a Micromill DSLS 3000 have YOU TRIED IT or are you just guessing it will work ? I NEED TO KNOW THAT IT WILL WORK
    Sep 2006
    607
    USB will not work no matter what. The PCMCIA will work with some laptops, but it's your best shot. It's the closes you will get to a true parallel port. I will buy 2 of these cards myself (a different brand though) for my mill and lathe. You don't really have any other choice except getting a stationary computer.
    PS. It's more important that he has tested it on the same type of laptop that you have and not the same machine. All the controllers for these type of machines are basicly the same.
  1. DSLS upgrade for Taig
    By warpedmephisto in forum Taig Mills / Lathes
    Last Post: 12-02-2007, 09:17 PM
  2. Taig DSLS 3000 vs. Super (Sieg) X3 CNC
    By msc in forum Taig Mills / Lathes
    Last Post: 04-19-2007, 10:08 PM
  3. toolchanger for micromill dsls
    By hatchmar in forum Benchtop Machines
    Last Post: 07-31-2006, 10:21 PM
  4. Questions about mini and micromill purchase
    By Hack in forum Benchtop Machines
    Last Post: 09-20-2004, 06:30 PM
