603,979 active members*
1,337 visitors online*
Results 1 to 11 of 11
    Sep 2004
    179
    Quick built router
    Heres a few photos of a router I threw together the last two weekends. I needed a router that could do bigger parts than my jgro router could for my V2 router in my build log on here, guess that makes this one V1.5 . One project is a race car bed for my step son, it was begging for a set of cnc cut wheels . I went with a moving table design this time and besides it taking up alot of extra space I really like the way it runs so far. One word of advice to all using all thread rod for lead screws, get a threading die! I picked one up and ran it over the rod with a drill ste at slow speed and sprayed down the rod with wd-40. The amound of shavings that came off were AMAZING at one point I had a 4" long ribbon of metel come out of the die. My old router had a few spots along the way that would bind up. I went thru three different lead screws and still ended up with problems, had I ran a die over it I bet I would'nt have had su8ch a problem. Anyway here are some pics.
    Attached Thumbnails Attached Thumbnails Picture 038.jpg   Picture 042.jpg   Picture 039.jpg
    Apr 2003
    23
    Talking Interesting Machine.
    Very insteresting design... Am I mistaken or the "out of center" leadscrew is because you are "restraining" horizontally on just one side ?? That way it will never bind, right ?
    Is the machine running yet ? Can you get some pictures of how precisely it can make cuts ? It seems so much easier to make than most designs so far...And it maybe more than enough for wood and plastics work.
    Best regards,
    Alexandre Guimaraes
    Sep 2004
    80
    Nice work, Darren! Good improv...!!
    Sep 2004
    179
    I offset the leadscrew simply because I thought it might work better closer to the side that it is restrained on, does it? so far so good.
    Here are a few pics I took tonight. All the cutting went great. The pics are of some wheels i'm doing for a race car bed for my step son who will be 6 on the 6th.
    Darren
    Mar 2005
    339
    Please, how did you clamp the raw material on machine in order to be machined?
    Sep 2004
    179
    if you look closely there are two drywall screws holding it down to the table. Kinda of a cheap way of doing it but it works well for me.
    Darren
    Mar 2005
    339
    Yeah. Sorry. I have seen it now.
    Apr 2005
    85
    Very nice machine! I have a question for you... how did you build the frame for the table? How did you make sure that welding the pieces together didn't bring them out of alignment/level?
    Feb 2005
    921
    Very Nice!
    Oct 2004
    85
    What feedrate do you run normally?
    Sep 2004
    179
    ignatz: the frame was something I had laying around and just happen to have the right dimentions for what I needed.
    Redline: The feedrate for cutting the wheels was 25ipm. While i was tweaking the machine the first night I had the rapids as high as 80ipm. I'm using a HobbyCNC 4 axis chopper board and 118 oz/in steppers
    Darren
  1. Techno-Isel CNC router for sale?
    By Noah in forum Commercial CNC Wood Routers
    Last Post: 11-28-2008, 05:12 AM
  2. Finding The Right Router
    By Crushmonkey in forum Commercial CNC Wood Routers
    Last Post: 06-19-2006, 07:17 AM
  3. Quick change router bit
    By wjbzone in forum DIY CNC Router Table Machines
    Last Post: 06-07-2005, 06:56 PM
  4. long term stability of wood framed router
    By dave925 in forum DIY CNC Router Table Machines
    Last Post: 05-06-2005, 05:33 AM
  5. Another home built router :)
    By steveald in forum DIY CNC Router Table Machines
    Last Post: 03-19-2005, 07:22 PM
