603,810 active members*
2,888 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Quick question on xylotex axis system kits
Results 1 to 4 of 4
    May 2006
    30
    Would it be possible to combine two xylotex 3 axis system kits hooked up to two parallel ports to make a 6 axis system?
    Mar 2003
    35494
    Depends on the software controlling them, but it should work.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2006
    30
    I believe I read the Mach3 supports two parallel ports, and if thats the case then the Xylotex kit is eactly what I'm looking for.
    I emailed Xylotex and asked them as well but I'm still waiting for a response.
    Mar 2003
    35494
    Yes, Mach3 should work.
    Gerry
