603,818 active members*
3,806 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Quick V18 Question
Results 1 to 4 of 4
    Oct 2003
    530
    Quick V18 Question
    I need to add a font called ireland.
    Anyone know how to add fonts?
    Also, I have a customer that wants me to engrave his signiture into a part. Is there a way to scan a signiture and import it into bobcad to engrave it?
    Thanks,
    Ed
    Aug 2003
    449
    In order:
    To add a new font to V18 you simply add it to your fonts folder;
    1) Go to your control panel
    2) open the fonts option
    3) go to "File" => "Install New Font"
    4) locate and install the new font
    (NOTE: BobCAD will only recognize true type fonts that is a ttf font. Anything else is ignored)
    There is a lot more work to scanning and vectorizing a signature in V18. It is best if you use some form of Rastor to Vector program.
    See BobART thread on this forum.
    Regards
    Oct 2003
    530
    Thanks,
    I got the font installed and it works good.
    I also downloaded a raster to vector program. It worked Ok. Imported into bobcad fine. There were a lot of disconnected lines and arcs. Is this normal or because of the r to v program?
    Thanks,
    Ed
    Aug 2003
    449
    The disconnected lines could be the result of either. The import of a dxf file from an outside CAD system. Or the way the program functions. BobCAD also offers a Rastor to Vector system, which works real well within the BobCAD system.
    Regards
  1. Extremely basic machining question.
    By touser in forum MetalWork Discussion
    Last Post: 06-19-2005, 06:51 AM
  2. A quick question?
    By Bartman in forum Solidworks
    Last Post: 05-31-2005, 03:24 AM
  3. Replies: 8
    Last Post: 12-21-2004, 10:22 PM
  4. Hobbycnc controler question
    By chas in forum Hobbycnc (Products)
    Last Post: 09-09-2004, 11:00 PM
  5. HF lathe question
    By rs1300 in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2004, 06:22 PM
