I thought this StealthChop technology by a German company Trinamic might be applicable to quieting the steppers on a Tormach. Hush noisy steppers with novel drive algorithm | EDN
If you ignore the fact that their chip is for two-phase steppers, and the Tormach uses three-phase steppers, so it would require swapping out the motors and motor drivers, and, in all probability power supplies. if you want quiet, use AC servos - they are virtually silent, and FAR faster.
Regards,
Ray L.
Note that the StealthChop approach to quieting 2 phase steppers is only effective at low stepping rates.
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
