587,613 active members*
4,607 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > R2020 Rutex connected to Siemens motors.
Page 1 of 2 12
Results 1 to 20 of 35
Hybrid View
    Oct 2004
    198
    Talking R2020 Rutex connected to Siemens motors.
    Firstly I'm moderately confident with stepper motors, I just haven't had much to do with servo's, so what better time to learn.
    Could I get some advise at to where/how I should connect the terminals onto the Rutex R2020 servo drive I've got, I understand the basics, it's just that the terminals on the motors have wires that I don't understand.
    For example in the encoder connection there is 2 red, 2 black, 2 yellow and 2 blue wires they just have 0.5 written next to them, not sure what this means.
    I understand the A,A+(I assume that's what the asterix means) B,B+ is.
    But I don't understand what the R, R+ and the W, W+ is. Any ideas?
    Also is an image of the motor connectors, thae last 2 wires are not attached (Actual Speed, Direction wires).
    I was going to ask about the motor connection but I just noticed on the R20x0 sheet it says R2010only. Well that's helpful considering it's the R2020.pdf help sheet.
    So any advise anyone could give would be muchly appreciated.
    Dec 2003
    24220
    R looks like reference or marker pulse (1/rev?) and the W says contamination signal, this is often a error signal fed back from the encoder, heidenhain encoders often have this.
    My guess anyway.
    Al.
    Albert E.
    Oct 2004
    198
    Hi Al,
    Thanks for the response, I'm just confused with what terminals I need on the RJ45 connection on the rutex.
    It has the following:
    Ch -A (non inv.)
    Ch -A (inv.)
    Ch -B (non inv.)
    Ch -B (inv.)
    Ch -I (non inv.)
    Ch -I (inv.)
    +5v
    0v/Signal Ground
    So in theory either the Reference pulse or the contamination signal terminals go to the Ch -I (non inv.) and Ch -I (inv.) connection???
    Also is the (inv.) the positive terminal and the (non inv.) the negative terminal?
    Am I even close?
    Does anyone have a connection diagram for the Rutex R2020 motor connections?
    Dec 2003
    24220
    The Ch-I's are the Index pulse or reference pulse, you can probabally leave the contamination signal unconnected, is the encoder a heidenhain by any chance?
    I just noticed that the diagram describes a linear scale pin-out?
    Al.
    Albert E.
    Oct 2004
    198
    Thanks Al, that makes sense to me now, I didn't realise that the Index Pulse and Reference pulse was the same thing.
    I'm not sure if it's a heidenhain encoder, even though it's a Siemens motor do they all use different brand parts?
    I can't find the linear scale out you mentioned, does this need to be connected as well?
    Dec 2003
    24220
    Its just that the diagram you posted refers to EXE60 linear measuring unit which is a Heidenhein scale and interface.
    It maybe a general connection diagram that covers many applications.
    Al.
    Albert E.
    Oct 2004
    198
    Well it turns out that the diagram for the motor is the same for the R2010 & the R2020.
    So on the rutex it has the following:
    Pin #1 +Vm DC Motor supply positive
    Pin #2 0V DC Motor supply return
    Pin #3 Mot.1 Motor terminal 1
    Pin #4 Mot.2 Motor Terminal 2
    On the servo motor it has the following terminals:
    Control voltage +24v
    Speed Controller enable
    Set speed, non-drive end
    Set speed
    Actual Speed, non-drive end
    Actual speed
    So I've got 4 terminals on the rutex, and 6 on the motor.
    So I need to work out which one's I don't need.
    Thanks again (still)
    Dec 2003
    24220
    Quote Originally Posted by Darc
    Set speed
    Actual speed
    According to the diagram that is not motor connections but Siemens servo drive connections, I don't see any motor details on the connection sheets.
    Al.
    Albert E.
    Oct 2004
    198
    Sorry I should of explained myself, I can't find any diagrams for the motors (not even siemens could help me) but I found some for the drive that they are attached to.
    So I was trying to work backwards to figure out what wires are what.
    Did that make any sense at all?
    Dec 2003
    24220
    I am assuming it is a DC motor, so apart from the encoder, there should be two large conductor armature wires, and if it is fitted with a tach, two smaller wires, that you do not need if Rutex drives operate in the torque mode.
    If You also find two other small wires, and if they show very low resistance (dead short) these could be a thermal detector.
    Confirm first it is in fact a DC motor.
    Al.
    Albert E.
    Oct 2004
    198
    I will ask our electrical man to have a look, but this is what's written on the motor.
    SIEMENS
    Perm-Magn-Mot.1 HU5042-0AF01-Z
    IEC50 NrE 7G915926 03 010
    V 1\min A Kw
    166 3000 4.7 0.656 S3-40%
    Mo 1.75Nm lo-4.0A VDF 0530 ICI F 100 K
    Err.excit V A Lv mh
    Permanent IP 54 IM B5
    Mo max 1.93Nm lo max 4.5A ICI F 130 K
    Tacho 1 HU1052 20mVmin Load 13 kΩ
    Z G42 Made in Germany
    Impulsgeber
    ROD 320 Imp 2000 /U
    Dec 2003
    24220
    Can't really tell if it is DC, but It looks like it has a tach and a Heidenhain ROD320 encoder 2000p/rev. Does it have a set of large brush holders on the rear end, apart from the tach which are smaller?
    Al.
    Albert E.
    Oct 2004
    198
    Here's some pics of the motor.
    Dec 2003
    24220
    Actually if it has a tach it more than likely is a DC motor, also it appears to be two conductors feeding the motor, brown & Blue?
    Al.
    Albert E.
    Oct 2004
    198
    Yeah your right, the 2 orange wires come out of the motor and are connected to the blue wire, and the 2 black wires coming out of the motor are connected to the brown wire.
    And there is a small connection as you mentioned, as you can see at the bottom.
    Jun 2005
    22
    Siemens motor
    This is a DC permanent magnet motor, I have them on my Beaver cnc mill with Fanuc 6M control. Normally they use 6RB20 Dc chopper feed drives. Also found on older cincinnati cnc lathes and mills.
    John.
  17. #17
    Jun 2005
    22
    Question Help!
    I am trying to repair my Beaver VC35 after the x axis ran away upon switch on.
    I've had both cards repaired, the stack card and the position card but when I got round to refitting them the servo set off again then the fanuc 6m control tripped out with x axis 410 and 401 alarms...
    Could it be the servo that is faulty?
    The brushes look next to new but oddly the servo seems to be holding voltage after the machine is switched off. (becomes hard to turn by hand)
    But..if I diconnect one of the servo power leads it becomes totally free..
    Then when I connect up again it becomes hard to turn once more.
    The servo is a Siemens 1HU DC permanent magnet 200v
    I can't understand why the motor would start without a command from the control side of things...?
    I tried swapping both cards with the y axis cards but got the same result.
    Then switched on ten minutes later with this same configuration and the motor didn't move, the position card just threw a red diode???? and the motor is only stiff to turn in one direction and not the other...
    I am lost!!
  18. #18
    Dec 2003
    24220
    The only other concern you may have is that some Heidenhain encoders had sine wave output and required an interface to square the pulses up, I have a library of heidenhain products but I could not find the ROD320, so you may want to confirm it with a 'scope if you have one available.
    Al.
    Albert E.
  19. #19
    Oct 2004
    198
    Unfortunately I don't have a scope, is there any other way I can check it?
    Thanks for all your help.
    If I connect the wires up in whatever suggested config, will the motor still work if it is meant to have an interface.
    I'm just hoping that maybe it will be unstable, so if I hook it up and it's o.k I can leave it.
  20. #20
    Dec 2003
    24220
    Unfortunately there is no easy way apart from a scope to find out, however the sine wave output is 1v peak to peak, and the squared up version is 5v TTL.
    Also I think you need to confirm the pin out connections, the sheet you show seems to be some other connection other than a ROD320. Do you have any Heidenhain representation in Australia that could help?
    Al.
    Albert E.
Page 1 of 2 12
