Hi
Need rack and pinion for cnc project. Where can i buy? Gauteng SA
:HENNIE
Hi
:HENNIE
do you intetested in buy it from China ?
lathe, turning,milling, grinding,CNC ,EDM,Injection Moulds, die casting mould
Carbide Inserts,Cutting Tool,Wear Parts
hi hennie
checkout Chains, Conveyor Components and Accessories, NUSAF ENGINEERING South Africa in wynberg close to sandton ,where are you based ?
Hennie,
If you'll drop me an email about what you need, I can put together a quotation. Diane@mooregear.com
CNC Direct every time. For components like this Greg is the go to person. If you want a belt gearbox I have a set spare.
