603,897 active members*
2,311 visitors online*
Results 1 to 4 of 4
    Apr 2006
    1016
    rack and pinion cnc router
    Has anyneo got or seen good plans for a nice
    mid side x,y table that uses rack and pinion ?
    Looking for ways to make a fast machine for routering mdf doors with biggest
    3hp router i can get or load which it can handle. kinda like the, muilt cam does in the below video clip
    but not that fast ...I only wished...lol
    http://www.youtube.com/watch?v=sflJe...elated&search=
    Jan 2007
    212
    If you scroll down in this forum, you will see one called "Another Aussie built router" or something like that. Read through it, he uses rack and pinion and does really nice work. As to whether there are a set of plans out there, I do not know.
    One thing you should know however, is that if you use rack and pinion, you will be able to achieve speeds like you saw in the video. That is the nature of R&P and belt drives, they can be very fast.
    If I were running a business that needed a large router for cutting doors, etc and I did not want to pay the higher cost of off the shelf stuff, I would draw up my plans after doing a lot of research, then have a smaller machine shop do all the grunt work, like making the table, fabricating some of the sections needed, etc. Then I would purchase the parts (rails, bearings, etc) and do the assembly work. If I were using steppers, I would do the electronics too. If I used servo's, then I would find an electronic guy to do the tuning of the drives required.
    Right now, I am building a medium size (which to me is a 28 X 38 machine). I am doing it all since I have the time. And it is definitely a homebuilt, MDF, hard maple, etc.
    Good luck on your endeavor!
    Mar 2006
    14
    Plans
    eloid,
    Check this site out, it has free plans and a great support forum also.
    http://www.mechmate.com/index.html
    The current plans are for a 4x8 machine but you could easily build a 4x4 .
    Tom
    Oct 2006
    735
    That was sweet..
    Personally I love having rack on my long axis 100" because you can move the gantry while it's powered down (if you have to) to get it out of the way of something while loading or something else. With screw based machines you could not move it with out rotating the screw.
    That said my Y is screw and so is Z. Which helps Z not plunge through the table when powered down..
    But Y limits my hi speed a bit (200ipm). I can do 6-800 if I want on x.. Some day I'll maybe switch Y to rack but not to soon. The thompson planitary that made my rack X possiable was not cheep (or should say would not have been so cheep if I didn't get it on ebay..hehe
    b.
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. Rack and pinion
    By TinkerDJ in forum Linear and Rotary Motion
    Last Post: 11-30-2005, 06:42 AM
  3. I need rack and pinion Help
    By t0m in forum Waterjet General Topics
    Last Post: 11-16-2005, 08:14 PM
  4. rack and pinion
    By planescott in forum Mechanical Calculations/Engineering Design
    Last Post: 10-11-2005, 09:28 AM
  5. Rack & pinion
    By coolman in forum DIY CNC Router Table Machines
    Last Post: 11-30-2004, 05:57 PM
