603,936 active members*
3,667 visitors online*
    Mar 2006
    58
    Rack and pinion inaccuracy
    Dear all, I built a cnc machine using rack and pinion mechanism for x and y motion.
    I use mach3 as a controller softwre, and the same settings were given to x and y axis.
    The y axis works great and precise.
    The problem is in the gantry (x axis), it is powered by two motors.sometimes it works great and other times the traveled distance is less by 3mm.
    Each side of the x gantry is driven by a motor, and the rack at each side is formed by two pieces : one of length 1 meter and the other is of length a half meter.
    Are the motors weak and i need powerful motors or the two rack pieces are not well aligned?? Any suggestion is really
    appreciated.
    Apr 2007
    1955
    There are several possibilities. Can you tell us a bit more about the setup:
    - motor rating
    - drivers
    - PS voltage
    - gear reduction
    - pinion size
    - rack pressure angle and pitch
    - is there good contact with the rack and pinion
    - speed you are trying to run at
    - acceleration settings
    - does it happen on slow speeds or just on fast
    Sorry to ask the details, but it does help.
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  3. anti_backlash rack for rack and pinion
    Last Post: 05-25-2011, 08:25 PM
  4. Rack and Pinion- rack tensioned to pinion?
    By Rees Guitars in forum Linear and Rotary Motion
    Last Post: 05-09-2011, 06:05 PM
  5. rack and rack & pinion with off the self planetary gearbox
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 12-06-2009, 03:54 PM
