603,383 active members*
3,369 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Radial rapid moves around axis are jerky
Results 1 to 5 of 5
    Oct 2007
    47
    Does anyone know what parameter setting smooths out radial rapid moves? Lets say I want to move off the part on a 5x mill, and rapid in 180degrees using basically C axis, then come back in on the other side of the part.
    I get a bunch of G0 lines to accomplish this that break up the arc into about 20 smaller G0 linear moves butt the machine pauses between each of the moves.
    Anyone know what's up?
    Mar 2008
    169
    Cam Program?
    Oct 2007
    47
    cam program doesn't matter. These are rapid moves.
    Imagine a series of G0 lines calling out a trace of a decagon (ten sides) around the C axis. as the machine interprets the rapid segments, it is only moving the C axis, but instead of just rotating 360 degrees in C smoothly, the C axis pauses ten times where each of the rapids start/end.
    Aug 2010
    156
    basically your not usually contouring in "G0" your only positiong if you want this motion smoother ghange them to a "G1" with a feed of F9999. see if that is more what your looking for.
    Oct 2007
    47
    G1 with high F output helps but the rapid override dial on the control doesn't slow these down and the NC has to be re-posted.
    On a DMG, the radial rapids are smooth and continuous. It is only on a fanuc control. Anyone? Machine dealers are no help on this unfortunately.
  1. Slow or Jerky G02 / G3 moves
    By ronateah in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2010, 11:35 PM
  2. Rapid tool moves when not cutting?
    By Fleck in forum G-Code Programing
    Last Post: 04-22-2009, 07:26 AM
  3. Newbie - torch dragging on rapid moves
    By bad-rat-57 in forum Waterjet General Topics
    Last Post: 07-10-2008, 12:45 PM
  4. Cycle Time for Rapid Moves and Tool Changes V9.1.1012 Turn
    By jmullett in forum Dolphin CAD/CAM
    Last Post: 02-07-2007, 11:32 AM
  5. Rapid moves G00
    By dicksonhof in forum Mach Software (ArtSoft software)
    Last Post: 11-07-2006, 04:21 PM
