For corner radius cutters, how do you set that up or what cutting strategy do you use? Thanks
Hi Scott,
This is how I created my tool...
Attachment 197298
See the attached SC Project file, I used 2D Contouring for the tooling op. You can tell from the project where I picked for the "Curve" and I choose top of the part as "Top Level" in Job Assignments and gave the bottom of the radius dimension (-.125") in Perimeters.
Gerry
Currently using SC7 Build 1.6 Rev. 64105
