I have a simple problem...
In my router, i am using circulating ball bearings. While mounting 20mm rails on the aluminium extrusions, i had to use M6 bolts. But plastic plugs do not fit to the holes because of these M6 bolts.
I only cut wood. Are wood dust damage the ball bearings?
Also i have the same problem with ball screws.
Until now, i have not any stall or damage problem in my screws and rail bearings. But in future i do not what the situation will be? I suppose wood dust do not give harm.
Can you make comments please?
