587,442 active members*
3,402 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Raised Panel Door Corners
Page 1 of 2 12
Results 1 to 20 of 21
    Feb 2012
    19
    Hey guys im trying to cut a wall pannel out of a 4'x 8' Of MDF it will have alot of rasied pannels on it, im useing an 1.5" ogee bit and the outside edges all come out radiused "as they should" is there a way in mastercam to solve this problem.
    Apr 2003
    3578
    so what is the problem as you said this how they should come out. so missing the issue can you post a file or a picture?
    Are you using Mastercam router or mill? and what version?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Feb 2012
    19
    Im using x6, router, im using a 5 axis router to cut these, i just know there has to be a way to clean out/up the outside rounded corners, they are rounded due to the bit radius.
    Apr 2003
    3578
    Can you share the file with me and I will give you a few ways. what level are you running. I am in the midle of programming a new Thermwood 5axis C90 right now.
    Cadcam
    Feb 2012
    19
    I have attached a DXF of the drawing it is very basic no surfaces or solids it is all 2d, I could not upload the mastercam file for some reason im using a 1.5" basic Ogee bit. we have a thermwood 5 axis M90, also i have level 3 mastercam so surface and solids.Feel free to ask questions thank you for the help.
    Attached Files Attached Files
    Mar 2003
    35538
    There are specialized door programs out there for making mdf doors, as well as bit sets. You usually need 3-4 different tools, depending on the profile.
    Looking at MasterCAM's website, I don't see MDF doors listed in the features.
    It would probably be much simpler with a dedicated door package.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2012
    19
    Industrial CNC Ogee Groove Router Bits by Amana Tool this is the type of tool that im using only mine is bigger in dia. sadly i dont think there is an easy way to do this,
    May 2004
    4519
    I think your problem here is you can't cut inside square corners with a cutting tool that is spinning in circles. Seems you are attempting to make faux-raised panel doors, not real ones. Sorry, but there is no "solution" to your problem. Either make real raised panel doors and assemble them or live with filleted inside corners.
    Feb 2012
    19
    Quote Originally Posted by txcncman View Post
    yes that is what im trying to do, i was a afriad that you would say that lol
    Apr 2003
    3578
    I finally got chance to open for file but I am not sure what you are trying to do. if you are trying to do corners Sharp that wont happen if you are trying to close to sharp corners then I can help. we can tapper the corner by taking your tool at a 45 deg for example and run it from the floor to the top using a tapered tool.
    Cadcam
    Mar 2003
    35538
    As I already said, there are many solutions, from free to thousands of $$
    Free
    Inexpensive
    (relatively)
    Expensive
    Also Expensive
    There are many more.
    But there is no simple one tool solution.
    Gerry
    May 2011
    108
    If you had AlphaCAM, this would be very easy.. But I know, that this don't help you in the moment...:drowning:
    Feb 2012
    19
    hey guys sorry i didnt get back to you'll quicker, but i would be ok if we could get the corners relatively sharp
    Apr 2003
    3578
    How about this software and it will not cost extra for you.
    Now I need more under standing of what you want with the basic wire you gave me, the shape you are trying to achieve so I can give you some thoughts to help get the shape..
    Cadcam
    May 2011
    108
    this is easy in AlphaCAM
    Door_sharp_corners - Lisbeth_B's library
    Mar 2003
    35538
    Quote Originally Posted by camnerd View Post
    Are you using the extra cost door module?
    If not, you can do the same thing in V Carve Pro for 1/10 the price.
    Gerry
  17. #17
    Apr 2003
    3578
    Gerry it is included in his Mastercam level at no cost . He asks how to do in in MC and we are pushing to buy something else not sure why?
    Cadcam
  18. #18
    Mar 2003
    35538
    I wasn't pushing anything to anyone. As I said, I didn't see any mention of those capabilities on their website. I checked again, and still don't see anything about doors, and I downloaded the .pdf and didn't see it in there, either.
    So I was just pointing out that there are specialized packages for doing MDF doors.
    Gerry
  19. #19
    Apr 2003
    3578
    Gerry, I am sorry if I came of harsh . as a Mastercam referral dealer and past dealer for part of the California area I don't try to push to much here either. Under the the Mastercam reseller retail list it even states the the standard level of router to include the following 2-3 axis milling, including 3D contouring , Drilling, pocketing, rectangular nesting, tabs, breakthrough machining, door geometry and links to popular cabinet packages and more.
    Gerry I am saying I think I came of a little hard and did not mean to it was getting frustrating as all I want to most of the time is help.
    I due thank you for your help and support here.
    Cadcam
  20. #20
    May 2011
    108
    I wasnt't pushing either - allthough I can see, it could be read that way..
    But I don't understand, that a simple job like that, is causing that much trouble - and if it's in the software - why not just ask your reseller to show how to use it..
Page 1 of 2 12
  1. Raised Door Panels
    By kolias in forum Autodesk
    Last Post: 04-22-2013, 08:24 AM
  2. Where to find DIY Servo motor for Car Door,panel,etc modify ?
    By Calico in forum Servo Motors / Drives
    Last Post: 12-09-2012, 03:42 PM
  3. Bypassing door hold and door locks on 2011 VF?
    By locash in forum Haas Mills
    Last Post: 04-05-2012, 04:31 PM
  4. raise panel door cnc
    By money1 in forum DIY CNC Router Table Machines
    Last Post: 08-12-2010, 03:29 AM
  5. Replies: 0
    Last Post: 03-11-2010, 05:30 PM
