587,680 active members*
3,636 visitors online*
    Apr 2013
    162
    RAMPS for a CNC Unimate lathe?
    Since I bought a Monoprice Select Mini 3D printer, my custom build hasn't gone anywhere. Thus I have the Arduino and RAMPS etc available for other uses.
    I picked up a Unimat SL1000 lathe and am thinking about converting it into a mini CNC lathe for making small things, including custom small screws and bolts. A pair of NEMA 17 motors will do fine, should be able to make 3D printed mounts, reinforced with urethane resin filling. (Definitely should work, someone made un-reinforced 3D printed mounts for larger motors on a new South Bend 8K lathe.)
    Is a RAMPS suitable for this? Can it accommodate a spindle pulse sensor for threading? I'm thinking of having the Arduino act as a motor controller, doing all the processing for curves etc while it gets instructions as a simple stream of g-code - like how a PLM2000 mill does with its internal servo controller and RS232 link.
    Ideally, I'd like the control system to not end up larger than the lathe.
    Jan 2005
    1943
    Re: RAMPS for a CNC Unimate lathe?
    None of the Arduino based cnc firmware that I know if does spindle synchronization. This is a deal killer for a lathe.
  1. 1.5W Laser on RAMPS 1.4
    By canteen234 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-31-2016, 02:06 AM
  2. zen toolworks cnc with ramps v1.4
    By journeyp in forum Zen Toolworks
    Last Post: 10-07-2015, 07:42 PM
  3. Ramps 1.4 vs Ramps 1.5.7
    By dregalia in forum DeskCNC Controller Board
    Last Post: 11-06-2014, 10:52 PM
  4. multipurpose ramps drivers
    By fadedwriter in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-18-2013, 06:02 AM
  5. cut ramps
    By guido_kp in forum Autodesk
    Last Post: 04-09-2007, 02:34 AM
