588,241 active members*
3,945 visitors online*
Results 1 to 6 of 6
    Mar 2005
    271
    rated current per phase
    ima little unsure about the amps to run this motor.its says the rated current/phase (amps dc) is 6.3. it says the number of phases is 4,and the holding torque with 2 phases on is 4.5 n.m. do the amps have to be multiplied by 4 or by 2 or is 6.3 the rating i need to set my drive to.any help would be greatly appreciated. thanks
    Jan 2006
    245
    The current is 6.3A, but this may be in series or parallel or even in unipolar if it is a 6 or 8 wire motor.
    Quote Originally Posted by CATCH22 View Post
    Motion Control Products Ltd
    www.motioncontrolproducts.co.uk
    Jun 2003
    3312
    Assuming this is an 8 wire motor and if the motor nameplates says 6.3A then that is the rating you would use for unipolar, or bipolar "half coil".
    Bipolar series would be 4.45A and normally bipolar parallel would be 8.9A. Bipolar parallel could be higher depending on mfg.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Mar 2005
    271
    here are the motor specs.
    if you go to this link on ebay it shows the motors and you can click on the link with the specs.sorry i tried everything to copy the pdf file and i couldnt do it,i also couldnt figure out how to copy and paste the link so all you have to do is click on it.so here it is hope someone dont mind looking at these for me.thanks again guys.
    http://cgi.ebay.com/ws/eBayISAPI.dll...2911&rd=1&rd=1
    Jan 2006
    245
    They are 6.3A in parallel or 3.2A in series, just set the driver to these currents dependant on how you connect the motor.
    The motor has 4 phases, and thes can either be connected in series are parallel to make 2 phases, parallel needs twice the current than series, and will also give you far better performance at the higher speeds due to the lower inductance.
    Forget the unipolar current unless you have a unipolar driver.
    I hope that helps.
    Mar 2005
    271
    excellent,thanks so much guys.
  1. G320 Suitability for a motor rated at 140 max volts?
    By sbalder in forum Gecko Drives
    Last Post: 04-12-2007, 09:56 PM
  2. Using a higher amp stepper than driver is rated for question
    By Semisentient in forum Stepper Motors / Drives
    Last Post: 04-21-2006, 11:57 PM
  3. current per phase, unipolar bipolar
    By Ragnarok in forum Stepper Motors / Drives
    Last Post: 02-23-2006, 04:57 AM
  4. Rated BLAC servo RPM
    By TommyB in forum Servo Motors / Drives
    Last Post: 04-16-2005, 07:02 PM
  5. current per phase for power supply?
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 07-31-2004, 06:41 PM
