587,699 active members*
3,477 visitors online*
Page 2 of 3 123
Results 21 to 40 of 52
Hybrid View
    Jan 2017
    41
    Re: Re-wiring a Gerber Sabre 408
    I messed up and cut the wires that I thought were redundant. nice and short. So now I have to buy new encoder connectors. The part numbers are as follows and they are not expensive, thankfully.
    211768-1 is the male plug coming off the machine encoder cable.
    The female is panel mounted onto the control box its manufacturer part number is 206705-1
    The contacts for the female panel mount socket are part number is 66102-3. I think they come supplied with the socket though.
    The extraction tool is part number 305183
    David hey, thanks for getting back to me. Yes I think I fixed that, so far as i can figure anyway. I bought a Dell PC power supply, and from that I am using 12v for the masso and 5v for the encoders and drives.
    So far as I can figure, the dell supply is isolated from the motor power supply, they both run to the wall socket, but after that they are separate and never meet.
    When I get the encoders working, and after I've finished reading your manual, I'll turn on the 74v power supply. It's hooked up but I have not done that yet. Nor have I looked at the tuna software. Im prettymuch taking it one step at a time, so first thing is to get the EA EB lights flashing, then I'll think about the next step. I ran out of plan a few days ago when I realised the wiring was done.
    Jan 2017
    41
    lights, letters. I bought red and blue and I was going with the blue but it shorted when I bent it. Looking at it I think orange might suit it. I'm going to get a flashing beacon on there as well, get faults to set it off, because machine.
    The below is how I will attach them. I used velcro so I can change out the strip. It'll take another on the lower half of the box. Bought an extractor tool for the connectors, waiting on the new pins for the connectors to arrive, monday.
    Apr 2018
    19
    Thanks so much for posting all of the detailed steps!
    I fear that I will have to perform the same upgrade on my own (Sabre 404) system. I am getting errors that I presume are caused by the driver board not communicating with one of the limit switches.
    My question is as to whether or not changing the driver board will affect anything about the display or control pad. Once you replaced the motor drives, does everything else work as original?
    Thanks!
    Jan 2017
    41
    Heya )
    my display will be a normal dell computer monitor, and to control it I'm, going to use a normal dell computer keyboard.
    All that's left from the original machine is the actual router, in my case
    The bigger control box is gone, I'm using the smaller one for everything
    The control pad is gone, i have no use for it.
    I'm not using the vacuum, but you could control that with the masso.
    I'm not using the original inverter cos I do not have three phase,
    I'm using a Chinese inverter to power the spindle.
    Maybe you could keep some of the functions of the control pad? Probably somebody else could, but it never crossed my mind. I understand why you would want to keep using it the way you have been, but i dont think it will make a very big difference in the event. Thinking about it, actually the display will be much bigger and the control software will be much less restrictive in a retrofitted machine.
    Apr 2018
    19
    Quote Originally Posted by ned_seven View Post
    Heya )
    Thanks for that info. I thought that might be the case. So far, my knowledge of these Gerber machines is still in the vocabulary-gathering stage.
    I think that the problem is with the cpu or the main driver board (if that’s what it’s called). I presume that my servo drive modules are still good, since all three axes move into their orienting positions, regardless of where the axes start. Do you or anyone on here know about who the driver module manufacturer is and any possible pinouts? I’m also open to being told that such an endeavor is a waste of time and buying new driver modules is the only reasonable option.
    EDIT: I just found the manufacturer: Elmo and model number SSA-8/100
    Even found the manual for them. http://www.elmomc.com/support/manuals/MAN_SSA_UG_EN_0698.pdf
    Jan 2017
    41
    I have two of those driver boards that im not using, you are welcome to them for the price of postage and packing, they are no good to me.
    I got the new driver boards working, weeeew! EA and EB are flashing when servo shaft is rotated.
    From here the wiring is all downhill, I think. My day job is hectic at the mo hence slow progress. Weather is getting better here in Ireland so trying to get the electrics done so i can work outside again in the evenings. (cmon cmon).
    Starting to think about a control box for the spindle next. Going to try re-use the reactor and line filter that the original VFD used, though its all for three phase. More reading to be done.
    Apr 2018
    19
    Wow! That would be amazing! I’ll send you a PM.
    Dec 2018
    I’m having the same issues what did you have to do to fix this issue
    Jan 2017
    41
    This is the larger control box. Its a very nice box, very well made. Its also huge. I'm going to chop it up and make a smaller box with it, for the VFD. Looking forwards to cutting and melting stuff after all this looking at wires.
    Jan 2017
    41
    All good.
    vfd box
    Have some more cutting to do, then weld it, then sort out a hinge for it. Looking good so far tho, the box transformed easily.
    Apr 2018
    19
    Forgive the newbie question. Here’s how I think the system is wired.
    My understanding of how you have wired your system is to replace the part that is in the dashed box (not exactly a box in the sketch) Also, I think that you replaced the servo amps as well (not in the dashed box)
    This means that you have replaced the four boards shown in the following picture. There is the bottom board (servo drive controller, I think??), the upper board (CPU and memory cards?) and the two peripheral interface boards (oriented vertically, one connects to a PC and the other connects to the handheld controller):
    Now here’s where I’m a little confused. My system has three of the following servo amps (X, Y and Z) mounted inside the lower part of the tower. Can you confirm that you replaced these in your new system? It appears that you did. I’m fairly confident that these are working ok in my system. I’m pretty sure that the problem with mine is the drive controller board up top and/or the CPU on top of it.
    If I do have to go this route, is the Masso controller the preferred magic box here or does anyone know of any recommended units?
    Thank you for all of the info and great documentation.
    Jan 2017
    41
    Tex yah,m no need to update the photos above, i understand what you mean without doing so.
    The servo (drives / amplifiers / amps) are located in the underside section, with the arrow in this pic. This is what I was going to send you. If they are fine, there is npo point in me sending you these.
    The motherboard is located in the top section where the star is. If this is broken, you are screwed, frankly. I have a motherboard i could send you but I think that is broken too, and you are looking at huge cash to have it repaired, so far as I can gather. So by far the cheaper option is to retrofit it with something more modern.
    I am a newbie too. I chose the masso because im a fan of simplicity, which the masso attempts to achieve. But its not a widely used unit, yet, so I cant offer any advice more than that,
    What I think you could or should do, is refer to the gerber wiring diagrams contained in this thread, I will complete them before this thread is done. Refer to them and then find a CNC enthusiast located near you thats willing to help you out. Join the facebook CNC router groups and ask if there is anyone located near you that will help. There are LOADS of facebook CNC groups.
    Or learn yourself. There is either effort or money required in any direction you choose here.
    If you want, I can post you every board I have, for the price of post and packing.
    They are sitting atop the machine at the moment and I don't want to throw them in the bin, it will make me feel good that they might be of some use to someone. Let me know, might be worth a try.
    Sep 2004
    5
    Ned_Seven,
    Any updates on your Gerber Saber?
    I just purchased a Gerber Sabre 408 last weekend. What a rock solid machine mechanically. :banana:
    Previous owner was told by the Gerber Tech he needed to replace the following Servo items Gerber Part #P61544B ($1,680) #P61529C ($532) #P61525C ($507).
    I'm still waiting to get access to the Gerber Online support docs so I can look online to see what parts are bad. They sent me a credit application to fill out and wanted proof of
    ownership before issuing me a user Id. to get access to their website. Everything is locked down.
    I want to replace/update the current proprietary controller system and add a water cooled spindle.
    At this point, I have 2 choices:
    1. Re-wiring controls using your method using existing Servos, Machdrives RBR and Centroid Acorn.
    2. Replace Servos with DMM DNY4 NEMA 34 ($1400) and Centroid Acorn. If I go this route I need have the Servo brackets machined to accept NEMA 34 motors which means removing ball screw nut.
    (I saw pictures Ned had posted of a Gerber Sabre machined to accept NEMA 34 steppers.)
    I would prefer No. 1 because of cost and time. Only problem is that I don't know if the existing servo is bad or even how to test it. How did you test to see if your servos and encoders were good.
    Karl
    Apr 2018
    19
    Quote Originally Posted by kawfree View Post
    Ned_Seven,
    Karl
    Karl,
    Is your machine doing anything at all?
    For mine, I think that I have determined the problem to be with the optical motor encoder on the Y-axis. I determined this by pulling the Y-motor and swapping it out with the X-axis. When I did this, the error on the controller display changed from listing a Y-axis error to listing an X-axis error.
    What errors are you getting?
    Tex
    Feb 2019
    Ned_Seven,
    Karl
    Where can I find these pictures of the nema34 conversion on the 404?
    Sep 2004
    5
    Sorry I just saw your post.
    Ned_Seven had posted pictures of a Nema34 conversion done by another Gerber Sabre 408 owner!
    https://www.cnczone.com/forums/comme...ml#post2076540
  17. #17
    Sep 2004
    5
    Ned_Seven or MachDrives
    Do you have a picture of your BRB CONFIGURATION and TUNING parameters for your Parvex Servos. I was able to get Encoder part working. The DRO gives me an exact count for 1 rotation. The problem is when I try running Tuna V2.07 wave generator I enable the Drive installing a jumper between EN and 0V. I put the values in the Proportional Gain and drive doesn't move. If I put too high of a value it faults the Motor and I need to power everything down again. Not really sure about my configuration. My Step/Dir counts per unit = 50 for full rotation which = 8 mm movement on the Axis while Encoder Counts per unit = 2000
  18. #18
    Jun 2009
    34
    Hi kawfree,
    If you need quicker support you can contact us directly on our support email address as we only check the forum occasionally. Your encoder counts sounds correct and you have verified it with the DRO. Your Step counts/unit is way too low. If your units are millimeters then set this to 200, if you are using inches then set this to 5000. You shouldn't be hard wiring the enable line, it should be controlled from your controller enable output. The drive disables on the high level and enables on the high to low transition. If you get a fault you don't need to power everything down, just toggle the enable line and you are good to go again. Also after changing your step or encoder counts toggle the enable line to recalculate the electronic gearing. What is the fault you are getting? I suspect it is following error. You can check the status flash count or the last 5 faults are listed on the Tuna monitoring tab. I suspect if you look the Tuna scope traces you will see the command trace starts heading up while the motor trace heads in the wrong direction (down) If so power down and reverse the motor wires and try again.
    Regards
    David
    Machdrives
  19. #19
    Jan 2017
    41
    Hi Karl, Tex )
    No progress really, work ramped up so I'm too tired in the evenings for hobbies. I'm tipping away, slowly like water. I'll get there. Regarding your post Karl, i would say use my diagrams for the machdrives, and the controller is up to you. Using the masso too makes it very simple for you. My encoder to machdrive diagram is not correct, i need to update it when i finally wire it.
    I got it working but I had to stop, life took over, other things to deal with. Never completed assembly. Will get there, maybe this weekend, though I doubt it. I have not even tested the servo motors yet! I think they are fine though. Will see soon enough.
  20. #20
    Jan 2017
    41
    Tfigs thanks ) Hope people find them as useful as I do. I know no other way to proceed. Have started disassembling the gerber, going to spend a few days scrubbing it. Then I am going to clompletely break it down and store it away while i reconfigure my shed. Im building a 6x10 plasma machine, then I will re-assemble the gerber when that is done.
Page 2 of 3 123
  1. Gerber Sabre 408 help...
    By crackstar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-19-2018, 01:29 PM
  2. Replies: 3
    Last Post: 05-22-2017, 12:02 AM
  3. Gerber Sabre 408
    By bulld101 in forum Gerber
    Last Post: 05-04-2016, 10:20 PM
  4. gerber sabre 408
    By nipon in forum Community Club House
    Last Post: 11-10-2013, 07:03 AM
  5. Gerber Sabre 408
    By Pasty in forum Want To Buy...Need help!
    Last Post: 07-21-2008, 03:52 PM
