Can anyone point me to any information on programming rear, or better yet, rear toolpost in conjunction with front?
I've read the one page in Using3Turn on rear toolposts, and Steve Blackmore's really good Mach3 Professional Turn PDF on setup unfortunately doesn't address rear toolposts at all. Neither does the Customizing Wiki.
I am planning to set up a small lathe with a rear toolpost for turning, and a front toolpost for cutoff, and a drill chuck in between, on a gang slide of sorts. Spindle will be unidirectional CW rotation, so the rear tool is upside down.
I'm familiar with lathe gcode (currently running TurboCNC on my Sherline lathe but will be tooling up with a new PC and Mach3,) but only with a front toolpost and a single tool. I have no idea how to handle arcs with the rear toolpost, for starters.
Anyway, I'll appreciate any guidance.
Best regards,
Randy
