587,227 active members*
3,601 visitors online*
    Apr 2011
    Recommendations
    I am looking for recommendations on how to trigger an e-stop from a G320x's err/res pin going low due to a fault. I would like Mach3 to know when a drive faulted.
    Apr 2004
    135
    Recommendations - G320X ERR signal
    The traditional way to support the ERR output from
    the G320X is trigger an emergency stop.
    There are several issues to consider when interfacing
    with the G320X's ERR/RES signal:
    1) This signal shares a ground reference with the motor
    power supply. If you want to retain the opto-isolation
    provided by Gecko on the Step and Direction inputs,
    you must also isolate the ERR/RES signal.
    2) The ERR/RES signal is not intended to directly drive
    most opto-couplers. There is a diagram of a buffered
    interface for an LED (or input of an opto-coupler)
    shown on the last page of the older G320 servo drive
    users manual. Look under legacy products on Gecko's
    web site to see the G320.
    3) The ERR/RES signal is both an input and an output.
    You must be able to pulse it with +5 volts to reset
    drives on power up, and then go back into a monitor
    the signal mode once they are running.
    The PMDX-126 provides a special I/O signal that provides
    all of the above. It will generate an emergency stop in
    response to an ERR from the G320X and will allow resetting
    the drivers from the host computer running Mach3. A full
    description of using the PMDX-126 with G320 or G320X servo
    drivers is shown in this application note:
    http://www.pmdx.com/Doc/AN125-2_GeckoRestart_01.pdf
    Regards,
    Steve Stallings
    www.PMDX.com
    Mar 2003
    35538
    Here's another option.
    Gecko Error Reset Controller
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Recommendations?
    By D VanderTaylor in forum EDM Discussion General Topics
    Last Post: 08-18-2011, 05:55 PM
  2. CNC RECOMMENDATIONS!
    By 8limes in forum Hobby Discussion
    Last Post: 06-25-2011, 04:21 AM
  3. CAD and CAM recommendations
    By S.Sharpe in forum Benchtop Machines
    Last Post: 11-17-2008, 10:38 PM
  4. Need some recommendations
    By DragnsBane in forum CNC Machine Related Electronics
    Last Post: 01-31-2007, 10:11 PM
  5. VFD recommendations?
    By split63 in forum Uncategorised MetalWorking Machines
    Last Post: 05-27-2006, 10:39 AM
