Have recently set up new M900 60W Engraver / Cutter from Redsail. Running Easycut 5.3 from XP Windows PC. Mirrors are aligned, lense is focussed BUT the laser cannot cut cleanly through business card stock paper. Have tried all power / speed combinations with poor results. At 60% power and 30% speed the laser will cut the paper but the slow speed means the edges of the cut are burnt.
Also, the datum point is 'lost' as laser will try and reset to datum by moving off the worktable. I have to stop and manually reset the laser to the start position. What's up?
Any ideas on where the problem is? I have emailed Redsail about the controller settings but no reply of value.
