I would like to reduce the height of some tubing using high speed machining. The tubing is to be put up at a slight angle and then I would like the cutter to go around the perimeter of the part shaving off about .01 spiraling inward. Or using high speed machining. I have to remove just short of .5 inches of material and would like to just go down to depth and either spiral in or high speed it.
