With the advice of Al (which I agree with) I am using the parameters to reference our turret on our Strippit running a GN-6 controller. The problem is that when ever I get it close the turret deviates way off I'll explain with the following numbers:
The controller has a diagnosis number to tell me how far off the turret is when I first started I set the parameter at 0 and with the locking pins in it showed the turret to be off by -2499 so I added 250 to the param. and rereferenced and then the turret was off by -2186. The following list will show what I changed the parameter to and what the turret was still off,
500 -1969
750 -1777
850 -1615
1000 -1430
1250 -1274
1500 -971
And then when I went to 1750 The turret went way out to -8709 (chair) I shut down and started up without changing and then it came back to 805so I proceded to 2000 and the turret was -499 so I went to 2250 and then it was back out to -8180 , 2150 -8382, 2000 -8434 So I went back to zero and it read -2461 changed to 2100 and out it went to -8328 back to 1500 and it was off -1013 This morning after being off all night: 1500 -996, 1700 -776,
1900 -583, 2100 -8399 By the way the turret is never been off in the opposite direction it is always the same direction off.
And here I sit :drowning: I'm not exactly sure what to figure I've cleaned the pulse coder "lense/disk" and checked to make sure all brushes were good on motor and tach since an old one we have had run it's tach brushes completely out and a past maintenance guy told the company they needed a whole new servo, but thats another story.
Hope someone can give me some advice any thing would be nice or I guess I will try to mechanically get it to home
Thank You,
Dustin
