Hi all .,
I have bought some used BK15 fixed supports for my cnc with 7002 angular bearings.
Now the bearings turn fine but i can see that dirt has gotten into the bearings as they have not been keept under a dust free enviroment.
Thus i have removed all the bearings and cleaned them up in petrol.
Now i need to grease them up , but i am uncertain if i can use Klübersynth LI 44-22 for my bearings , or do i need to get the NBU-15 grease ?
I mean there is no high speed use on those bearings as these are only to turn my 2010 ballscrews and i never run over 9600 mm/m on my machine ( 9600 is fast travel and not cutting speeds )
But even though im not running speeds then i wanna use the correct grease for optimal lifetime on my bearings![]()
Hope someone can help out here
Kris
