588,137 active members*
6,683 visitors online*
Results 1 to 7 of 7
    Sep 2008
    64
    Removing Rust off pull studs?
    I have some pull studs for my BT35 tool holders but there a little rusted any tips on how to remove the rust without damaging the pull stud?
    Jan 2005
    1943
    I use oxalic acid, otherwise known as wood bleach to remove rust. Mostly I"ve done this for chrome parts, but I have also done it on painted parts and it doesn't hurt the chrome or paint. Not sure about other coatings/finishes. Itis a powder that you mix with water and then drop the parts in. Leave them for 24-36 hours and the rust will be gone. Just a light brush with a soft plastic bristle brush. Probably 1 tablespoon to a quart of water should work. If you can't find wood bleach you can also use "super iron out".
    Jan 2006
    2985
    Is this surface rust or is there pitting involved too?
    If it's not too bad, wire brush (powered) them then soak in kerosene or similar and then buff with scotchbrite. Oil them good so this doesn't happen again.
    Matt
    Sep 2008
    64
    Mostly surface rust but what if it has pittting?
    May 2004
    4519
    Pitting will cause extra (excessive) wear on the tool retention hardware in the spindle. Would you rather buy a few new retention pull stud knobs, or rebuild the drawbar mechanism in your machine? Your choice.
    Jan 2005
    15362
    Techbuilder
    If you have more than just a light rub/wipe with scotch-brite, replace them
    Mactec54
    Sep 2008
    64
    Good to know thank you guys
  1. Bridgeport VMC1000 Pull Studs
    By BetaBob in forum Bridgeport / Hardinge Mills
    Last Post: 06-08-2016, 12:11 PM
  2. Haas Pull Studs
    By rrbmachining in forum Haas Mills
    Last Post: 08-12-2013, 01:22 PM
  3. Pull studs – use thread locker?
    By helocat in forum Haas Mills
    Last Post: 06-09-2010, 05:17 AM
  4. pull studs
    By najnielkp in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2009, 02:42 AM
  5. Tree vmc1050 pull studs
    By rbpower in forum Tree
    Last Post: 03-06-2009, 06:31 PM
