603,936 active members*
2,597 visitors online*
Results 1 to 12 of 12
    Apr 2004
    439
    renco encoder info needed
    Oct 2003
    927
    here's the info site.....I figured mine from this...
    http://www.renco.com/106001.htm
    red and black are correct
    I believe white is A and green is B
    yellow is A not and blue is B not ( you won't connect these if you are using step/dir drivers)
    Feb 2004
    2337
    I have already gone through this, and posted it in this thread.
    http://www.cnczone.com/forums/showth...&threadid=3920
    Being outside the square !!!
    Apr 2004
    439
    think you bloy2004 and ynneb found with what you gave me and found some posts over on the gecko yahoo forum im all set really to go
    Apr 2004
    439
    Thanks again for everyones help this is a great forum
    Oct 2003
    927
    sendkeys:
    I got some motors(cheapos) that had the 1024 ppr rencos but couldn't remove them as they sealed the hub to the motor shaft with something like locktight. since I wasn't going to use the motor with that high ppr, I busted, sawed, punched untill I had a zillion pieces of what once was an encoder. Now I can install
    the US digital 250's that I got a while back.
    Note: After destroying the renco, I noticed at that renco site the instructions for removal......which gave sources for the necessary solvent to apply to the hub/shaft to "loosen" or disolve the thin sealant between......
    Apr 2004
    439
    bloy ya i just saw your messages over on the yahoo forum small world Helped me out alot too
    now i got to price step multipliers or new encoders
    Feb 2004
    2337
    If you are using Rutex cards then you will not need step multipiers since they are built into the card them selves. You can adjusts the multipiers with the onboard switches.
    Jul 2004
    83
    What are step multipliers??
    Jun 2003
    866
    Step multiplier means that the control goes more encoder counts per step. I woulda thought that 1024 is plenty low resolution, it's a very common resolution for servomotors. But then again, I haven't really looked that hard at step and direction controllers.
    Jul 2004
    83
    I am looking at some servo motors that come with 1000ppr encoders attached to
    motor. plan to use gecko 340's. are these motors going to work???
    New to the servo world.
    Chas
    Jun 2003
    866
    Quote Originally Posted by chas
    Chas
    Chas, they certainly would work. Let's say that your computer could put out 10000 steps per second. If you are using a 1000ppr encoder, that means you have 4000 steps per rotation, or 10000/4000 = 2 1/2 rotations per second. On my machine, I have 2:1 gearing between the motor and shaft, and 5 tpi, so that means I could go 10000 steps per second/4000 steps per rotation * 1/5 inch per rotation / 2 rev per rev gear ratio = 1/4 inch per second, or 15 inchs per minute. That's too slow. Now with the 340's step multiplier, you could go up to 10 encoder counts per second, or 150 ipm. That may be too fast for your machine, which is ok because you can limit it in software.
    Now, my number of steps per second from the computer is a bit low, so you'd have to find out what your computer is capable of and decide how much you wanted to move per step before you set the multiplier.
    Again, using my machine as an example, the resolution would be 1/5 inch per rev * 1/2 (rev per rev gear ratio)/(4000 counts per rev) or 0.000025 inch per step with 1x multiplier, which is a little small, so you would probably be happy with the 10x multiplier.
  1. CNC conv. info help needed
    By Texasj10 in forum Shopmaster/Shoptask
    Last Post: 03-12-2010, 11:36 PM
  2. Info needed for these servos
    By Splint in forum CNC Machine Related Electronics
    Last Post: 11-10-2008, 10:24 AM
  3. Lathe info needed
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 06-01-2007, 10:45 PM
  4. looking for info on HP encoder
    By CNC Darren in forum Servo Motors / Drives
    Last Post: 02-06-2005, 07:10 PM
